Wifi/BT Connector
hello, I would like to know if possible to use SDIO port expander like TI txs02612 for example,
For connect mmc/Bluetooth, WLAN
(01-25-2016, 05:37 AM)hazerty Wrote: hello, I would like to know if possible to use SDIO port expander like TI txs02612 for example,
Looks like possible but may be messy. Are you thinking to support eMMC ontop of current Wifi/BT port?
.. TL
yes I am agree with you..
[Image: ?nav=item.view&alt=web&id=331757725455&globalID=EBAY-US]Wifi/BT sub Hey guys I have a question will this wifi/Bt you find in eBay would work for the pine? Here's how it looks like.
http://pages.ebay.com/link/?nav=item.vie...ID=EBAY-US
(03-14-2016, 10:32 PM)Eddy120876 Wrote: [Image: ?nav=item.view&alt=web&id=331757725455&globalID=EBAY-US]Wifi/BT sub Hey guys I have a question will this wifi/Bt you find in eBay would work for the pine? Here's how it looks like.
There is no chip information, and no idea whether will work.
Oh man. Thanks anyways tllim. Looks like I might have to take the plunge once my pine arrives, and then report back.
I have already ordered to check out. This site selling cheaper: http://www.ebay.com/itm/111713126352?_tr...EBIDX%3AIT
Oh wow tlim thanks for the headsup. Can't wait to see what you found out. Also hoping for my p64 gets here before Easter. Since I will be off during the entire weekend  Big Grin
I tried the one that is compatible with Raspberry Pi - https://www.sparkfun.com/products/13677 - Edimax WiFi Adapter (EW-7811UN)
it doesn't work Sad
(03-27-2016, 08:19 PM)arpanj2 Wrote: I tried the one that is compatible with Raspberry Pi - https://www.sparkfun.com/products/13677  - Edimax WiFi Adapter (EW-7811UN)
it doesn't work Sad
Oh man that sucks  Sick
  [split] Better WiFi/BT module? moriel5 3 10,638 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 8,809 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 43,431 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 7,278 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 33,915 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 16,886 09-11-2018, 02:02 PM
Last Post: gamelaster
  Installing another WiFi module on one of the buses mido2018 1 6,207 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 24,882 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 10,153 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
Sad wifi direct bj_jung 2 8,540 12-29-2016, 10:26 AM
Last Post: happytuna
