Persistent Linux system on USB and/or SD?
I've used mkusb to make persistent Ubuntu on USB to travel with. Are or can any of the the many distros Ayufan is generously providing be persistent, as in a removable contained system on SD or USB with persistent files and prefs?
I realize we're early in the process here, and getting stabilized is the highest priority and i support that 100%.
Just a thought
zaius apparently answered my question in another thread:
The SD is now your system drive. So any changes such as passwords, settings, updates, etc. are going to be written to it.
https://forum.pine64.org/showthread.php?tid=7920&page=6
Thank you!
I think this depends on if it was built into the kernel/initrd. I used to use this to run multiple live systems from the same EFI partition and the persistent storage on its own partition. I ran Kali, Remix OS and ParrotSec OS this way on the older MacBooks (2008).
Take a look at how other live Linux CDs boot configurations (grub.conf / syslinux.conf / etc) to get an idea of how they made it work.
From my experience, this took a lot of trail and error. I haven't looked at the post you linked yet, I'll check it out soon.
Working as a Film Electric and I have been using Linux since around 2002.
Like to play with Python and Jupyter Lab/Notebooks when not going to the park with my baby girl.
  Can’t login to Linux fnosai 0 3,551 07-27-2025, 12:30 AM
Last Post: fnosai
  Void Linux: missing firmware from pinebookpro-firmware? remph 0 3,586 12-15-2024, 01:58 PM
Last Post: remph
  Attempting to install Void Linux, boots into a black screen 9a3eedi 1 7,195 09-28-2024, 09:23 AM
Last Post: throwawayforvoid
  Slackware Linux working on PBP vxzero 0 4,258 06-05-2024, 04:30 PM
Last Post: vxzero
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 4,239 03-01-2024, 06:46 PM
Last Post: Puckla
  Fedora 36 -> 37 upgrade kills system tydeman 0 2,475 10-28-2023, 09:53 AM
Last Post: tydeman
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 7,610 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 3,451 07-13-2023, 05:21 PM
Last Post: owaspfap
  Kali Linux for Pinebook Pro Luke 100 284,840 05-03-2023, 06:10 AM
Last Post: dachalife
  DiY - Installing Void Linux ARM On The Pinebook Pro vincele 1 4,109 11-28-2022, 05:03 PM
