Haaalp! Any experience with Pine64 Android problems!
Shocked
Finally my little pine has arrived \o/ Big Grin
Tried to install Pine Android (Pine A64 Android Lollipop Image Rev 2016012). I receive a message that android is starting, optimizing apps 42/42. After process is finished, pine restarts and process is starting all over again. Somekind of a loop. Constantly optimizing apps, restarts, optimizing aps, restarst....  Huh
Any advice pls?
I found some information online that suggest it's an app issue, but since it hasn't booted up fully without restarting, i'm not sure. I would try formatting your SD card, and burning the same image to it. If a clean install doesn't fix it, we can do some more investigating.
If I've helped you with something, please leave a rating for my responses.
(04-05-2016, 06:28 AM)pine.tree Wrote: I found some information online that suggest it's an app issue, but since it hasn't booted up fully without restarting, i'm not sure. I would try formatting your SD card, and burning the same image to it. If a clean install doesn't fix it, we can do some more investigating.
Thank you for your reply! Smile
I tried in first place on smaller card, it was same. I thought it is because of its size (only 8 gb). Then I tried with bigger (16gb) it was clean install. I can try again.
 On some other forums I find similar issue, but only with phones with same android. Their sollution was to stop charging their phone while booting. Unfortunatelly i cant do it here  Big Grin ...
I just found that if i unplug lan cable Pine starts normaly. But restarst after i plug it in.
Sent from my B1-723 using Tapatalk
2gb a64 model?
If you like my work be sure to check out my site or wish to donate to the cause
Cheers Big Grin
Yes, it is Smile
This is an issue they are working on for the 2GB models something we experienced in the Linux sphere up until last week.
Cheers Big Grin
Just wait until they fix bug?
(04-08-2016, 06:36 AM)ebreake Wrote: Just wait until they fix bug?
Good info in this forum: http://forum.pine64.org/showthread.php?tid=579
Thanks. Useful info [WHITE SMILING FACE]
  Need help compiling android for pine a64 + YeeticusMaximus22 2 2,610 08-20-2026, 08:45 AM
Last Post: ahegarosib97
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 607,303 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 50,185 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 32,031 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 12,683 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 14,250 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 10,564 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 6,748 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 409,287 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 7,506 02-26-2019, 11:58 AM
Last Post: Twistedx
