Upgrading Debian Stretch image to Buster
I installed a while ago ayufan's Debian Stretch image on a Rock64 as a server, and wanted to know if it was possible to upgrade it directly to Debian 10 Buster by following the standard upgrade procedure (i.e by changing the repo versions in /etc/apt/sources.list), or if there was some things to be taken care of first, like switching to another custom repo, switching kernels, etc.).
Thanks in advance !
Yeah thier is a sed hack that replaces the version as a script.
sed -i '$ a\\ndeb http://packages.dotdeb.org wheezy all\ndeb-src http://packages.dotdeb.org wheezy all' /etc/apt/sources.list
This was on stackexhange..
At any case buster instead of wheezy, and likewise your local arm64 mirrors...
Apt distro upgrade , (something like that)
similar sed trick will replace all
"Old-distro-codename" with buster.. using sed..
And also easily in /apt/sources file/s..
Also a apt sources generation site. ,
Adds many things ie dropbox Google's chrome etc.
may need to edit, as some are arm7hf or x86 or amd64,
Or sdeb.. if that can get sdeb and build locally..
I typically use Gentoo anyway, but as emmc build root ... debian been used as xdcard host.
Sent from my SM-N960U using Tapatalk
https://linuxize.com/post/how-to-upgrade...10-buster/
This has main article you might like and sed stretch to buster..
Did you check the upgrade instructions on https://github.com/ayufan-rock64/linux-build/releases? I guess they would be a good starting point, plus a change from stretch to buster in /etc/apt/sources.list.
  Upgrading ancient Rock64 timxjr1300 1 4,380 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  problem with debian emmc boot G4zCDzWb 10 31,263 11-01-2024, 04:32 PM
Last Post: bits
  Debian installation via sd card oaFJSADBKV 0 2,767 10-12-2024, 10:24 AM
Last Post: oaFJSADBKV
Smile First Lakka image for Rock64! Luke 47 120,157 09-01-2024, 06:05 AM
Last Post: RaymondDay
  How to update/compile Debian 12.5? Wizardknight 3 5,370 03-29-2024, 05:01 AM
Last Post: gedas07
  Rock64 Debian 11 (Bullseye) install problem jbize 15 25,566 10-12-2023, 05:14 PM
Last Post: tpaul
  rock64-debian-mrfixit-190531.img.xz : missing /usr/lib/dri/rockchip_dri.so popi 5 10,468 08-12-2021, 04:55 AM
Last Post: igorp
  Debian build from mrfixit2001 Luke 18 45,067 05-17-2021, 02:35 AM
Last Post: Wizzard
  NextCloudPi image for Rock64, NC version 13.0.2. nachoparker 11 38,837 03-15-2021, 02:59 PM
Last Post: kiriakos
  Debian kernel stuck at 4.4.167 Enig123 5 11,064 12-29-2020, 12:57 PM
Last Post: kwinz
