KDE Neon Image - Where can i find the Kernel Source ?
i run a modified KDE Neon Image on EMMC and want to compile some kernel modules
but i`m not sure what files i should get, is the pine64 kernel the same ?
Ayufan`s Repository is listen some versions.
But i`m not sure what i`m running i have 3.10.105-bsp-1.2 from 27 Oct.
I only need to the Source Code Tarball to compile 3G Modem Drivers.
can anyone point me in the right direction ?
Matthias
https://github.com/longsleep/linux-pine6...5-0-pine64
this is only for pine64 right ? is there something else for pinebook ?
EDIT:
https://github.com/ayufan-pine64/linux-b.../README.md
but this is still not the same kernel running on pinebook :/
(08-12-2019, 07:04 AM)matze79 Wrote: https://github.com/longsleep/linux-pine6...5-0-pine64
EDIT:
As kde neon it is debian/ubuntu based, you just need to install the kernel sources package:
apt-get source <packagename>
And to get the list of installed packages dpkg -i
HTH
yeah but there is no source package.
i already tried that and modified sources.list.
EDIT:
git clone --depth=1 --branch=my-hacks-1.2-with-drm --single-branch https://github.com/ayufan-pine64/linux-pine64.git linux
But.. i still have no modsyms so full rebuild is needed
Rebuild kernel with every driver needed, and it works.
i extracted every info i needed from ayufans build scripts.
Maybe if i get the video issue fixed i will upload my emmc image.
Also now spotting OpenHantek, with 3.10 kernel and egl it does work fine with my scope Smile
  Write image to eMMC - Pinebook 11.6" irongarment 4 10,931 01-04-2022, 09:22 PM
Last Post: irongarment
  Pinebook 1080p / KDE Neon freezes every 5-10 min pyrrhumain 12 28,783 11-02-2019, 10:03 AM
Last Post: rookieone
  Kernel 5.2 and OpenSource Mali Driver matze79 13 30,071 09-27-2019, 11:09 AM
Last Post: macacob
  KDE Neon Pinebook remix edition RC image bshah 66 181,918 05-18-2019, 11:44 AM
  Tips and Tricks for Ayufan's Bionic LXDE Image NoraCodes 8 18,100 01-22-2019, 06:22 PM
Last Post: binholz
  MAME on Standard KDE Neon Corkonian 2 6,455 12-19-2018, 02:06 AM
Last Post: Corkonian
  kernel 4.x erchache2000 6 13,468 11-21-2018, 12:10 PM
Last Post: boballen55
  Pinebook 1080 brand new kde Neon Snaps jwp1000 0 3,441 11-21-2018, 06:38 AM
Last Post: jwp1000
  KDE Neon problems persisting (1080) ImmortanJoe 8 16,003 11-18-2018, 02:22 AM
Last Post: ImmortanJoe
  activate repository in kde neon Luca Tansini 1 4,642 11-15-2018, 09:57 AM
Last Post: Luke
