Touchscreen LCD replacement
I wonder if we would be able to replace the included panel with a touch screen one?
(08-10-2019, 07:55 AM)Jcarlos Wrote: I wonder if we would be able to replace the included panel with a touch screen one?
Interesting question.
One thing that is needed for a new input device, is the hardware input port. We'd have to look at the schematics of the Pinebook Pro and see what was available. Without looking, the only un-used internal I/O that I know of, are the PCIe lanes, 4 of them. (I don't know if touch panels use separate I/O from the display I/O.)
A nice thing about open designs is that you actually do get to see the schematics and block diagrams. Plus we can request design changes for version 2 of the system board. Like bringing out un-used I/O ports to board connectors. (Instead of having to solder to board traces or chip pins.) This is one of my personal projects, get to know Pinebook Pro's internals.
Arwen Evenstar
Princess of Rivendale
Well there is no TP port on the PCB, so I cannot see how you'd do that.
It is possible to transfer touch data via DisplayPort AUX.
Though I don't know if rk3399 can handle this well.
Some touchscreens have a separate eDP connector for the display and USB cable for the touch (can come in different forms, such as FPC, etc.), so if you were desperate to attach a touchscreen, you could connect such a touchscreen in place of one of the external USB ports (I'm assuming there aren't any spare/unused USB connections exposed anywhere inside).
Problems with this approach:
  • * Routing the touch USB cable out of the screen into the base.
  • * One less USB port, unless you can find space to squeeze a hub in.
You could use a nano hub prob can squeeze it inside and reroute an external port.
https://www.tindie.com/products/mux/nano...-projects/
  Replacement battery for PineBook Pro DrYak 5 9,191 02-28-2026, 09:17 PM
  Replacement main board for Developers mozes 11 14,266 11-17-2024, 04:32 AM
Last Post: reukiodo
  Replacement touch pads Sb2024 0 2,740 11-14-2024, 10:05 PM
Last Post: Sb2024
  Bad replacement battery? chris88233 4 6,995 11-14-2024, 06:05 PM
Last Post: reukiodo
  Keyswitch scissors replacement cmj 1 3,715 10-14-2024, 05:35 PM
  Battery replacement mjc 2 6,596 09-26-2023, 01:08 AM
Last Post: david-lechner
  Replacement scissor switches (ANSI keyboard)? zackw 3 8,276 08-09-2021, 09:20 PM
  Pinebook Pro/Pinetab replacement as400 11 21,900 07-30-2021, 04:40 AM
Last Post: as400
  Replacement board avaliability mrjay 1 4,818 07-06-2021, 04:08 PM
  Replacement for video cable (EDP to LCD/camera)? pnwkayaker 2 7,005 10-13-2020, 08:42 PM
Last Post: pnwkayaker
