slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#51
Updated Slackware Aarch64 Miniroot (ROCK64) 20190201 on Wiki and PINE64 Installer.
Updated Slackware Aarch64 XFCE (ROCK64) 20190201 on Wiki and PINE64 Installer.
updated kernel (ayufan 4.4.167-1213)
kernel for slarm64:
kernel-firmware-rk3328-4.4.183-aarch64-1mara.txz
kernel-headers-rk3328-4.4.183-aarch64-1mara.txz
kernel-modules-rk3328-4.4.183-aarch64-1mara.txz
kernel-rk3328-4.4.183-aarch64-1mara.txz
update packages:
1. download all listed files
2. sudo upgradepkg kernel-*.txz
update:
- kernel 4.4.183
- update all packages Sat Jun 22 19:14:18 UTC 2019
slarm64-current-aarch64-base-rootfs-15Jun19-4.4.183-rock64-build-20190623.img.xz
slarm64-current-aarch64-base-rootfs-15Jun19-4.4.183-rock64-build-20190623.img.xz.md5
slarm64-current-aarch64-xfce-rootfs-15Jun19-4.4.183-rock64-build-20190623.img.xz
slarm64-current-aarch64-xfce-rootfs-15Jun19-4.4.183-rock64-build-20190623.img.xz.md5
Updated Slackware Aarch64 Miniroot (ROCK64-v3/v2 and ROCK64-v2) 20190623 on Wiki and PINE64 Installer.
Updated Slackware Aarch64 XFCE (ROCK64-v3/v2 and ROCK64-v2) 20190623 on Wiki and PINE64 Installer.
(07-02-2019, 08:16 PM)pineadmin Wrote: Updated Slackware Aarch64 Miniroot (ROCK64-v3/v2 and ROCK64-v2) 20190623 on Wiki and PINE64 Installer.
I installed the XFCE version. The system hung repeatedly. The first two times during initial start-up, when resizing the sd card, than later on when the mouse was moved in the XFCE session. I think I tried the Miniroot version, too, that also hung. I tried different sd cards to make sure that was not an issue. I used etcher to install the image.
I used to have a  PC-based slackware router that I wanted to reimplement on the rock64. Unfortunatelly, I had to go with Armbian stretch at the end, because I could not use slackware, but I would like to go back to slackware if possible. How stable/reliable slackware on the rock64? Have you had good feedback? I'll try the next release. When will you have it?
Thanks,
Karl
Thanks,
Karl
Please ensure the Micro SD Card is UHS-1 class. If used lower class such as Class 2 Micro SD Card is too slow to use and can get the whole system runs in to low performance or sometimes crash.
Thanks,
pineadmin....
Thanks,
Karl
Thanks,
pineadmin....
This is what I used:
Kingston Canvas Select 16GB microSDHC Class 10 microSD Memory Card UHS-I 80MB/s R Flash Memory Card with Adapter (SDCS/16GB)
Quote:I installed the XFCE version. The system hung repeatedly. The first two times during initial start-up, when resizing the sd card, than later on when the mouse was moved in the XFCE session. I think I tried the Miniroot version, too, that also hung. I tried different sd cards to make sure that was not an issue. I used etcher to install the image.
I will look at performance over a long period.
while the problem of the correct booting and operation of the system from the SDcard with the eMMC module connected is noticed.
when disconnecting the eMMC boot and works fine
I don't have an eMMC module.
I'll give it another try with another SD card, and if that doesn't work, I'll have to throw in the towel.
KarlF,
Left the board to work the day the image of the sfke, no problems were detected, SDCard samsung SD EVO PLUS 32Gb.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 18,694 06-27-2026, 02:43 PM
  rAudio for Rock64 V2/Pine A64+ shinzuka 11 1,854 06-25-2026, 03:16 PM
Last Post: shinzuka
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,128 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,028 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,958 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,231 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,408 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,396 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 86,653 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 110,490 09-01-2024, 06:05 AM
