RETRO GAMING: UPDATED RECALBOX FOR THE RK3399 ROCKPRO64
#21
(05-27-2019, 10:32 AM)Mrfixit2001 Wrote: Updated release - PCIe issues are now resolved!
https://github.com/mrfixit2001/recalbox_...tag/190527
Hi Mrfixit2001,
Thank you for all of your hard work!  I was wondering if you are planning to release a version for the Rockpro64 with the new Recalbox 6.0 Dragonblaze (since it is not possible to upgrade from 5.0)?
#22
Actuall yes - good news is coming! I am first working on an updated release to fix the emmc boot issue and update the kernel. Should be out tonight or tomorrow.
As for 6.0 Dragonblaze - once I have the pinebook pro desktop all sorted and ready, I will be rebasing my entire recalbox port against their master repo and then finally merging my work into theirs so that they will have the Pine64 boards in their main repo!
#23
Updated release:
https://github.com/mrfixit2001/recalbox_...tag/190603
- Kernel Updated to 4.4.180
- Additional Kernel Fixes
- U-Boot patched to fix weird issue where only some EMMC modules will not boot
Special thanks to y0sh for being the only volunteer to help test solutions to the emmc issue, as I was unable to reproduce it myself
#24
thank you for your work Cool
if not, how to add frequencies for overclock the cpu?
thank you Smile
#25
Updated Recalbox - 190603 on Wiki and Pine64 Installer
#26
New image is now available for download
#27
(07-20-2019, 04:07 AM)Luke Wrote: New image is now available for download
Luke, I think you posted this in error. Rock64 has a new image. Rockpro64 does NOT.
#28
Hello
Today I've tried to install the new version recalbox_rockpro64_190603
But the last version doesn't boot from my eMMC.
EDIT : The EMMC was corrupted. Now it works on a micro sd
I have another question. When I use my micro sd as roms storage I can shutdown the system properly.
If I use my harddrive as a roms storage, the sytem will  reboot instead of shut down. Today it was not shutdown after having clicked on "reboot" it showed me kodi. Is there a file that should be edited on my hard drive to let recalbox shutdown?
Thank you
#29
As I see, Recalbox is version 5, is there any chance that it can be upgraded to version 6?
#30
(01-16-2020, 11:19 AM)Maxpako Wrote: Hello,
Yes, being worked on. Probably within a month.
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 23,015 09-27-2026, 11:42 AM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 183,688 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 3,427 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  RK3399 PCIe enumeration jhadd 0 3,512 01-31-2024, 08:56 AM
Last Post: jhadd
  yocto for RockPro64 Fide 1 5,264 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 10,377 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,976 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 131,983 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,909 05-21-2023, 11:34 PM
Last Post: shpark
  rk3399 and Visual Output Processor 2 (VOP2) swan 3 7,851 05-13-2023, 12:01 AM
Last Post: swan
