rockpro64 4gb dont boot
hi all,
I can not flash a system on the rockpro64. have used various SD cards and also various systems. it is the rockpro64 board v2.1 with 4gb RAM and power supply from the pine shop. I was able to read the following about uart with minicom.
[code]DDR Version 1.12 20180518
In
Channel 0: LPDDR4,50MHz
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
Bus Width=32 Col=10 Bank=8 Row=15/15 CS=2 Die Bus-Width=16 Size=2048MB
Channel 1: LPDDR4,50MHz
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x4D
MR14=0x4D
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
256B stride
channel 0
CS = 0
MR0=0x98
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0 training pass!
channel 1 training pass!
change freq to 400MHz 0,1
channel 0
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x1
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
change freq to 800MHz 1,0
ch 0 ddrconfig = 0x101, ddrsize = 0x2020
ch 1 ddrconfig = 0x101, ddrsize = 0x2020
pmugrf_os_reg[2] = 0x3AA1FAA1, stride = 0xD
OUT
U-Boot SPL board init
U-Boot SPL 2017.09-rockchip-ayufan-1025-g482cd6ec8b (Jul 26 2018 - 08:18:48)
booted from SD
Trying to boot from MMC2
NOTICE:  BL31: v1.3(debug):d98d16e
NOTICE:  BL31: Built : 15:03:07, May 10 2018
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
WARNING: check_cpu_wfie: 1, 0, 69632, error!
WARNING: check_cpu_wfie: 1, 1, 139264, error!
INFO:    plat_rockchip_pmu_init(1151): pd status e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE iniK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-rockchip-ayufan-1025-g482cd6ec8b (Jul 26 2018 - 08:18:55 +0000)
Model: Pine64 RockPro64
DRAM:  3.9 GiB
DCDC_REG1@vdd_center: ; enabling (ret: -121)
DCDC_REG2@vdd_cpu_l: ; enabling (ret: -121)
DCDC_REG3@vcc_ddr: ; enabling (ret: -121)
DCDC_REG4@vcc_1v8: set 1800000 uV; enabling (ret: -121)
LDO_REG1@vcc1v8_dvp: set 1800000 uV; enabling (ret: -121)
LDO_REG2@vcc3v0_touch: set 3000000 uV; enabling (ret: -121)
LDO_REG3@vcc1v8_pmu: set 1800000 uV; enabling (ret: -121)
LDO_REG4@vcc_sd: set 3300000 uV; enabling (ret: -121)
LDO_REG5@vcca3v0_codec: set 3000000 uV; enabling (ret: -121)
LDO_REG6@vcc_1v5: set 1500000 uV; enabling (ret: -121)
LDO_REG7@vcca1v8_codec: set 1800000 uV; enabling (ret: -121)
LDO_REG8@vcc_3v0: set 3000000 uV; enabling (ret: -121)
SWITCH_REG1@vcc3v3_s3: ; enabling (ret: -38)
SWITCH_REG2@vcc3v3_s0: ; enabling (ret: -38)
vcc1v8-s0@vcc1v8_s0: set 1800000 uV; enabling (ret: -38)
dc-12v@dc_12v: set 12000000 uV; enabling (ret: -38)
vcc-sys@vcc_sys: set 5000000 uV; enabling (ret: -38)
vcc3v3-sys@vcc3v3_sys: set 3300000 uV; enabling (ret: -38)
vcc-phy-regulator@vcc_phy: ; enabling (ret: -38)
vdd-log@vdd_log: ; enabling (ret: -38)
MMC:   sdhci@fe330000: 0, dwmmc@fe320000: 1
SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
*** Warning - bad CRC, using default environment
In:    serial@ff1a0000
Out:   serial@ff1a0000
Err:   serial@ff1a0000
Net:   eth0: ethernet@fe300000
Hit any key to stop autoboot:  0
Card did not respond to voltage select!
mmc_init: -95, time 20
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:7...
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
1055 bytes read in 21 ms (48.8 KiB/s)
select kernel
1:      kernel-4.4.132-1075-rockchip-ayufan-ga83beded8524
2:      kernel-4.4.132-1075-rockchip-ayufan-ga83beded8524-memtest
Enter choice: 1:        kernel-4.4.132-1075-rockchip-ayufan-ga83beded8524
Retrieving file: /boot/initrd.img-4.4.132-1075-rockchip-ayufan-ga83beded8524
2923481 bytes read in 147 ms (19 MiB/s)
Retrieving file: /boot/vmlinuz-4.4.132-1075-rockchip-ayufan-ga83beded8524
19703816 bytes read in 870 ms (21.6 MiB/s)
append: rw panic=10 init=/sbin/init coherent_pool=1M ethaddr=8e:07:6b:97:17:e4 4
Retrieving file: /boot/dtbs/4.4.132-1075-rockchip-ayufan-ga83beded8524/rockchipb
67025 bytes read in 109 ms (599.6 KiB/s)
## Flattened Device Tree blob at 01f00000
   Booting using the fdt blob at 0x1f00000
   Loading Ramdisk to f5c3a000, end f5f03bd9 ... OK
   Loading Device Tree to 00000000f5c26000, end 00000000f5c395d0 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.132-1075-rockchip-ayufan-ga83beded8524 (root@r8
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: Early serial console at MMIO32 0xff1a0000 (options '')
[    0.000000] bootconsole [uart0] enabled
[    0.000000] Reserved memory: failed to reserve memory for node 'drm-logo@000B
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.0 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] PERCPU: Embedded 21 pages/cpu @ffffffc0f7eec000 s46248 r8192 d316
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pa2
[    0.000000] Kernel command line: earlycon=uart8250,mmio32,0xff1a0000 swiotlb4
[    0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[    0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 byte)
[    0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] software IO TLB [mem 0xf7ea3000-0xf7ee3000] (0MB) mapped at [fff]
[    0.000000] Memory: 3965100K/4061184K available (11966K kernel code, 1706K r)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     modules : 0xffffff8000000000 - 0xffffff8008000000   (   128 )
[    0.000000]     vmalloc : 0xffffff8008000000 - 0xffffffbdbfff0000   (   246 )
[    0.000000]       .init : 0xffffff8009080000 - 0xffffff80091a0000   (  1152 )
[    0.000000]       .text : 0xffffff8008080000 - 0xffffff8008c30000   ( 11968 )
[    0.000000]     .rodata : 0xffffff8008c30000 - 0xffffff8009080000   (  4416 )
[    0.000000]       .data : 0xffffff80091a0000 - 0xffffff800934a808   (  1707 )
[    0.000000]     vmemmap : 0xffffffbdc0000000 - 0xffffffbfc0000000   (     8 )
[    0.000000]               0xffffffbdc0008000 - 0xffffffbdc3e00000   (    61 )
[    0.000000]     fixed   : 0xffffffbffe7fb000 - 0xffffffbffec00000   (  4116 )
[    0.000000]     PCI I/O : 0xffffffbffee00000 - 0xffffffbfffe00000   (    16 )
[    0.000000]     memory  : 0xffffffc000200000 - 0xffffffc0f8000000   (  3966 )
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[    0.000000] Hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 64.
[    0.000000]  RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=6.
[    0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=6
[    0.000000] NR_IRQS:64 nr_irqs:64 0
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] ITS: /interrupt-controller@fee00000/interrupt-controller@fee20000
[    0.000000] ITS: allocated 65536 Devices @f2d00000 (psz 64K, shr 0)
[    0.000000] ITS: using cache flushing for cmd queue
[    0.000000] GIC: using LPI property table @0x00000000f2c90000
[    0.000000] ITS: Allocated 1792 chunks for LPIs
[    0.000000] CPU0: found redistributor 0 region 0:0x00000000fef00000
[    0.000000] CPU0: using LPI pending table @0x00000000f2ca0000
[    0.000000] GIC: using cache flushing for LPI property table
[    0.000000] GIC: PPI partition interrupt-partition-0[0] { /cpus/cpu@0[0] /cp}
[    0.000000] GIC: PPI partition interrupt-partition-1[1] { /cpus/cpu@100[4] /}
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop0_frack
[    0.000000] rockchip_clk_register_frac_branch: could not find dclk_vop1_frack
[    0.000000] Architected cp15 timer(s) running at 24.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycless
[    0.000005] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398s
[    0.001951] Console: colour dummy device 80x25
[    0.002375] console [tty0] enabled
[    0.002706] bootconsole [uart0] disabled
[    0.003109] Calibrating delay loop (skipped), value calculated using timer f)
[    0.003137] pid_max: default: 32768 minimum: 301
[    0.003261] Security Framework initialized
[    0.003278] Yama: becoming mindful.
[    0.003309] AppArmor: AppArmor disabled by boot time parameter
[    0.003371] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.003392] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.004181] Initializing cgroup subsys io
[    0.004206] Initializing cgroup subsys memory
[    0.004247] Initializing cgroup subsys devices
[    0.004267] Initializing cgroup subsys freezer
[    0.004287] Initializing cgroup subsys net_cls
[    0.004305] Initializing cgroup subsys perf_event
[    0.004325] Initializing cgroup subsys net_prio
[    0.004349] Initializing cgroup subsys hugetlb
[    0.004365] Initializing cgroup subsys pids
[    0.004413] ftrace: allocating 44383 entries in 174 pages
[    0.118679] sched-energy: Sched-energy-costs installed from DT
[    0.118710] CPU0: update cpu_capacity 401
[    0.118775] ASID allocator initialised with 32768 entries
[    0.121996] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@feed
[    0.122497] Platform MSI: /interrupt-controller@fee00000/interrupt-controlled
[    0.123794] Detected VIPT I-cache on CPU1
[    0.123825] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.123856] CPU1: using LPI pending table @0x00000000f2f40000
[    0.123899] CPU1: update cpu_capacity 401
[    0.123903] CPU1: Booted secondary processor [410fd034]
[    0.124436] Detected VIPT I-cache on CPU2
[    0.124457] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.124485] CPU2: using LPI pending table @0x00000000f2f60000
[    0.124515] CPU2: update cpu_capacity 401
[    0.124518] CPU2: Booted secondary processor [410fd034]
[    0.125056] Detected VIPT I-cache on CPU3
[    0.125076] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.125104] CPU3: using LPI pending table @0x00000000f2fc0000
[    0.125131] CPU3: update cpu_capacity 401
[    0.125135] CPU3: Booted secondary processor [410fd034]
[    1.131347] CPU4: failed to come online
[    1.131771] CPU4: failed in unknown state : 0x0
[    2.137972] CPU5: failed to come online
[    2.138002] CPU5: failed in unknown state : 0x0
[    2.138050] Brought up 4 CPUs
[    2.138078] SMP: Total of 4 processors activated.
[    2.138110] CPU features: detected feature: GIC system register CPU interface
[    2.138148] CPU: All CPU(s) started at EL2
[    2.138202] alternatives: patching kernel code
[    2.139351] devtmpfs: initialized
[    2.158953] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[    2.159037] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    2.159628] xor: measuring software checksum speed
[    2.169242]    8regs     :  1468.000 MB/sec
[    2.179293]    8regs_prefetch:  1316.000 MB/sec
[    2.189346]    32regs    :  1984.000 MB/sec
[    2.199397]    32regs_prefetch:  1664.000 MB/sec
[    2.199427] xor: using function: 32regs (1984.000 MB/sec)
[    2.199490] pinctrl core: initialized pinctrl subsystem
[    2.202100] Failed to find legacy iommu devices
[    2.202692] NET: Registered protocol family 16
[    2.211549] cpuidle: using governor ladder
[    2.223594] cpuidle: using governor menu
[    2.224196] vdso: 2 pages (1 code @ ffffff8008c36000, 1 data @ ffffff80091a4)
[    2.224274] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    2.224838] DMA: preallocated 1024 KiB pool for atomic allocations
[    2.291975] raid6: int64x1  gen()   269 MB/s
[    2.309024] raid6: int64x1  xor()   257 MB/s
[    2.326152] raid6: int64x2  gen()   441 MB/s
[    2.343211] raid6: int64x2  xor()   347 MB/s
[    2.360344] raid6: int64x4  gen()   652 MB/s
[    2.377414] raid6: int64x4  xor()   451 MB/s
[    2.394527] raid6: int64x8  gen()   527 MB/s
[    2.411561] raid6: int64x8  xor()   412 MB/s
[    2.428680] raid6: neonx1   gen()   492 MB/s
[    2.445741] raid6: neonx1   xor()   453 MB/s
[    2.462823] raid6: neonx2   gen()   746 MB/s
[    2.479885] raid6: neonx2   xor()   664 MB/s
[    2.497016] raid6: neonx4   gen()  1011 MB/s
[    2.514088] raid6: neonx4   xor()   757 MB/s
[    2.531152] raid6: neonx8   gen()  1035 MB/s
[    2.548251] raid6: neonx8   xor()   783 MB/s
[    2.548281] raid6: using algorithm neonx8 gen() 1035 MB/s
[    2.548312] raid6: .... xor() 783 MB/s, rmw enabled
[    2.548341] raid6: using intx1 recovery algorithm
[    2.550901] vcc3v3_pcie: supplied by dc_12v
[    2.551658] vcc_sys: supplied by dc_12v
[    2.552417] vcc3v3_sys: supplied by vcc_sys
[    2.554150] iommu: Adding device ff8f0000.vop to group 0
[    2.554262] platform ff8f0000.vop: iommu /iommu@ff8f3f00 not found
[    2.554294] iommu: Removing device ff8f0000.vop from group 0
[    2.554400] iommu: Adding device ff900000.vop to group 0
[    2.556138] SCSI subsystem initialized
[    2.556622] usbcore: registered new interface driver usbfs
[    2.556709] usbcore: registered new interface driver hub
[    2.556827] usbcore: registered new device driver usb
[    2.556997] media: Linux media interface: v0.10
[    2.557068] Linux video capture interface: v2.00
[    2.557186] pps_core: LinuxPPS API ver. 1 registered
[    2.557218] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[    2.557288] PTP clock support registered
[    2.558955] Advanced Linux Sound Architecture Driver Initialized.
[    2.559684] Bluetooth: Core ver 2.21
[    2.559742] NET: Registered protocol family 31
[    2.559772] Bluetooth: HCI device and connection manager initialized
[    2.559811] Bluetooth: HCI socket layer initialized
[    2.559845] Bluetooth: L2CAP socket layer initialized
[    2.559901] Bluetooth: SCO socket layer initialized
[    2.560434] NetLabel: Initializing
[    2.560464] NetLabel:  domain hash size = 128
[    2.560492] NetLabel:  protocols = UNLABELED CIPSOv4
[    2.560567] NetLabel:  unlabeled traffic allowed by default
[    2.561883] clocksource: Switched to clocksource arch_sys_counter
[    2.643514] thermal thermal_zone1: power_allocator: sustainable_power will bd
[    2.643904] NET: Registered protocol family 2
[    2.644542] TCP established hash table entries: 32768 (order: 6, 262144 byte)
[    2.644954] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[    2.646072] TCP: Hash tables configured (established 32768 bind 32768)
[    2.646219] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[    2.646440] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[    2.646984] NET: Registered protocol family 1
[    2.647444] RPC: Registered named UNIX socket transport module.
[    2.647478] RPC: Registered udp transport module.
[    2.647507] RPC: Registered tcp transport module.
[    2.647537] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.648593] Trying to unpack rootfs image as initramfs...
[    2.822530] Freeing initrd memory: 2852K
[    2.823429] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte
[    2.823567] hw perfevents: failed to probe PMU!
[    2.823597] hw perfevents: failed to register PMU devices!
[    2.825111] kvm [1]: 8-bit VMID
[    2.825141] kvm [1]: Hyp mode initialized successfully
[    2.825325] kvm [1]: interrupt-controller@fff20000 IRQ10
[    2.825602] kvm [1]: timer IRQ12
[    2.828793] audit: initializing netlink subsys (disabled)
[    2.828888] audit: type=2000 audit(2.739:1): initialized
[    2.829823] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    2.839543] VFS: Disk quotas dquot_6.6.0
[    2.839776] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    2.842143] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    2.843712] NFS: Registering the id_resolver key type
[    2.843779] Key type id_resolver registered
[    2.843809] Key type id_legacy registered
[    2.843853] Installing knfsd (copyright © 1996 okir@monad.swb.de).
[    2.844723] fuse init (API version 7.23)
[    2.845746] JFS: nTxBlock = 8192, nTxLock = 65536
[    2.851859] SGI XFS with ACLs, security attributes, realtime, no debug enabld
[    2.854110] Key type big_key registered
[    2.854233]
[    2.854233] TEE Core Framework initialization (ver 1:0.1)
[    2.854311] TEE armv7 Driver initialization
[    2.854970] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[    2.855007] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[    2.855294] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[    2.859438] NET: Registered protocol family 38
[    2.859502] Key type asymmetric registered
[    2.859537] Asymmetric key parser 'x509' registered
[    2.859824] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[    2.860057] io scheduler noop registered
[    2.860095] io scheduler deadline registered (default)
[    2.860170] io scheduler cfq registered
[    2.862351] phy phy-ff770000.syscon:usb2-phy@e460.0: Failed to get VBUS suppr
[    2.870662] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-0
[    2.870730] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Cha2
[    2.872804] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-0
[    2.872864] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Ch6
[    2.874695] pwm-regulator: supplied by vcc_sys
[    2.875716] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    2.877937] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 35, base_baud =A
[    2.992346] console [ttyS2] enabled
[    2.994375] [drm] Initialized drm 1.1.0 20060810
[    3.000421] [drm] Rockchip DRM driver version: v1.0.1
[    3.001563] usbcore: registered new interface driver udl
[    3.004307] Unable to detect cache hierarchy for CPU 0
[    3.005968] brd: module loaded
[    3.012724] loop: module loaded
[    3.013093] lkdtm: No crash points registered, enable through debugfs
[    3.015932] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[    3.016554] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[    3.017180] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[    3.018490] m25p80 spi32766.0: gd25q128 (16384 Kbytes)
[    3.019019] 3 ofpart partitions found on MTD device spi32766.0
[    3.019561] Creating 3 MTD partitions on "spi32766.0":
[    3.020057] 0x000000000000-0x0000003f8000 : "loader"
[    3.021715] 0x0000003f8000-0x000000400000 : "env"
[    3.023218] 0x0000007c0000-0x000000800000 : "vendor"
[    3.027370] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    3.028047] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    3.028577] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
[    3.029138] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    3.029966] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    3.030608] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    3.036197] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    3.036895] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    3.037366]  Ring mode enabled
[    3.037661]  DMA HW capability register supported
[    3.038080]  Normal descriptors
[    3.038419]  RX Checksum Offload Engine supported (type 2)
[    3.038937]  TX Checksum insertion supported
[    3.039339]  Wake-Up On Lan supported
[    3.039731]  Enable RX Mitigation via HW Watchdog Timer
[    3.110398] libphy: stmmac: probed
[    3.110748] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[    3.111355] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01)
[    3.114066] Rockchip WiFi SYS interface (V1.00) ...
[    3.114642] usbcore: registered new interface driver cdc_ether
[    3.115250] usbcore: registered new interface driver rndis_host
[    3.117704] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[    3.124289] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[    3.126530] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.127171] ehci-pci: EHCI PCI platform driver
[    3.127666] ehci-platform: EHCI generic platform driver
Your u-boot is outdated. Please use a newer one.
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
(05-01-2019, 07:57 AM)Bullet64 Wrote: Your u-boot is outdated. Please use a newer one.
I have now updated u-boot but the result is the same. Maybe you have another approach?
DDR Version 1.19 20190305
In
channel 0
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 0
CS = 0
MR0=0x98
MR4=0x81
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
channel 1
CS = 0
MR0=0x98
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
CS = 1
MR0=0x18
MR4=0x3
MR5=0xFF
MR8=0x8
MR12=0x72
MR14=0x72
MR18=0x0
MR19=0x0
MR24=0x8
MR25=0x0
Channel 0: LPDDR4,800MHz
Channel 1: LPDDR4,800MHz
256B stride
OUT
U-Boot SPL 2017.09-rockchip-ayufan-1045-g9922d32c04 (Mar 21 2019 - 17:27:29)
booted from SPI flash
Trying to boot from SPI
NOTICE:  BL31: v1.3(debug):370ab80
NOTICE:  BL31: Built : 09:23:41, Mar  4 2019
INFO:    plat_rockchip_pmu_init(1181): pd status e
INFO:    SPSR = 0x3c9
U-Boot 2017.09-rockchip-ayufan-1045-g9922d32c04 (Mar 21 2019 - 17:27:35 +0000)
DRAM:  3.9 GiB
In:    serial@ff1a0000
Scanning mmc 1:7...
1055 bytes read in 31 ms (33.2 KiB/s)
select kernel
6357095 bytes read in 709 ms (8.6 MiB/s)
19703816 bytes read in 2131 ms (8.8 MiB/s)
67025 bytes read in 166 ms (393.6 KiB/s)
  Loading Ramdisk to f58f2000, end f5f02067 ... OK
  Loading Device Tree to 00000000f58de000, end 00000000f58f15d0 ... OK
Starting kernel ...
[    0.000000] Memory: 3961744K/4061184K available (11966K kernel code, 1706K r)
[    0.000000] ITS: allocated 65536 Devices @f2900000 (psz 64K, shr 0)
[    0.000000] GIC: using LPI property table @0x00000000f2890000
[    0.000000] CPU0: using LPI pending table @0x00000000f28a0000
[    0.001949] Console: colour dummy device 80x25
[    0.002374] console [tty0] enabled
[    0.002705] bootconsole [uart0] disabled
[    0.003107] Calibrating delay loop (skipped), value calculated using timer f)
[    0.003135] pid_max: default: 32768 minimum: 301
[    0.003277] Yama: becoming mindful.
[    0.003393] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[    0.004180] Initializing cgroup subsys io
[    0.004245] Initializing cgroup subsys devices
[    0.004265] Initializing cgroup subsys freezer
[    0.004285] Initializing cgroup subsys net_cls
[    0.004302] Initializing cgroup subsys perf_event
[    0.004322] Initializing cgroup subsys net_prio
[    0.004346] Initializing cgroup subsys hugetlb
[    0.004362] Initializing cgroup subsys pids
[    0.004410] ftrace: allocating 44383 entries in 174 pages
[    0.118859] sched-energy: Sched-energy-costs installed from DT
[    0.118890] CPU0: update cpu_capacity 401
[    0.118954] ASID allocator initialised with 32768 entries
[    0.122189] PCI/MSI: /interrupt-controller@fee00000/interrupt-controller@feed
[    0.122657] Platform MSI: /interrupt-controller@fee00000/interrupt-controlled
[    0.123960] Detected VIPT I-cache on CPU1
[    0.123992] CPU1: found redistributor 1 region 0:0x00000000fef20000
[    0.124022] CPU1: using LPI pending table @0x00000000f2b40000
[    0.124065] CPU1: update cpu_capacity 401
[    0.124069] CPU1: Booted secondary processor [410fd034]
[    0.124601] Detected VIPT I-cache on CPU2
[    0.124622] CPU2: found redistributor 2 region 0:0x00000000fef40000
[    0.124650] CPU2: using LPI pending table @0x00000000f2b60000
[    0.124679] CPU2: update cpu_capacity 401
[    0.124683] CPU2: Booted secondary processor [410fd034]
[    0.125221] Detected VIPT I-cache on CPU3
[    0.125241] CPU3: found redistributor 3 region 0:0x00000000fef60000
[    0.125269] CPU3: using LPI pending table @0x00000000f2bc0000
[    0.125297] CPU3: update cpu_capacity 401
[    0.125301] CPU3: Booted secondary processor [410fd034]
[    1.131483] CPU4: failed to come online
[    1.131907] CPU4: failed in unknown state : 0x0
[    2.138084] CPU5: failed to come online
[    2.138115] CPU5: failed in unknown state : 0x0
[    2.138163] Brought up 4 CPUs
[    2.138191] SMP: Total of 4 processors activated.
[    2.138223] CPU features: detected feature: GIC system register CPU interface
[    2.138261] CPU: All CPU(s) started at EL2
[    2.138317] alternatives: patching kernel code
[    2.139493] devtmpfs: initialized
[    2.159090] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ms
[    2.159174] futex hash table entries: 2048 (order: 5, 131072 bytes)
[    2.159770] xor: measuring software checksum speed
[    2.169364]    8regs     :  1468.000 MB/sec
[    2.179415]    8regs_prefetch:  1316.000 MB/sec
[    2.189468]    32regs    :  1984.000 MB/sec
[    2.199519]    32regs_prefetch:  1664.000 MB/sec
[    2.199550] xor: using function: 32regs (1984.000 MB/sec)
[    2.199604] pinctrl core: initialized pinctrl subsystem
[    2.202284] Failed to find legacy iommu devices
[    2.202878] NET: Registered protocol family 16
[    2.211732] cpuidle: using governor ladder
[    2.223777] cpuidle: using governor menu
[    2.224358] vdso: 2 pages (1 code @ ffffff8008c36000, 1 data @ ffffff80091a4)
[    2.224435] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    2.225000] DMA: preallocated 1024 KiB pool for atomic allocations
[    2.292135] raid6: int64x1  gen()   269 MB/s
[    2.309182] raid6: int64x1  xor()   257 MB/s
[    2.326254] raid6: int64x2  gen()   441 MB/s
[    2.343361] raid6: int64x2  xor()   347 MB/s
[    2.360473] raid6: int64x4  gen()   652 MB/s
[    2.377503] raid6: int64x4  xor()   449 MB/s
[    2.394658] raid6: int64x8  gen()   527 MB/s
[    2.411694] raid6: int64x8  xor()   412 MB/s
[    2.428841] raid6: neonx1   gen()   492 MB/s
[    2.445865] raid6: neonx1   xor()   453 MB/s
[    2.462957] raid6: neonx2   gen()   746 MB/s
[    2.480054] raid6: neonx2   xor()   666 MB/s
[    2.497150] raid6: neonx4   gen()  1011 MB/s
[    2.514220] raid6: neonx4   xor()   757 MB/s
[    2.531281] raid6: neonx8   gen()  1035 MB/s
[    2.548384] raid6: neonx8   xor()   783 MB/s
[    2.548415] raid6: using algorithm neonx8 gen() 1035 MB/s
[    2.548445] raid6: .... xor() 783 MB/s, rmw enabled
[    2.548474] raid6: using intx1 recovery algorithm
[    2.551017] vcc3v3_pcie: supplied by dc_12v
[    2.551793] vcc_sys: supplied by dc_12v
[    2.552554] vcc3v3_sys: supplied by vcc_sys
[    2.554307] iommu: Adding device ff8f0000.vop to group 0
[    2.554416] platform ff8f0000.vop: iommu /iommu@ff8f3f00 not found
[    2.554449] iommu: Removing device ff8f0000.vop from group 0
[    2.554555] iommu: Adding device ff900000.vop to group 0
[    2.556296] SCSI subsystem initialized
[    2.556782] usbcore: registered new interface driver usbfs
[    2.556869] usbcore: registered new interface driver hub
[    2.556987] usbcore: registered new device driver usb
[    2.557158] media: Linux media interface: v0.10
[    2.557229] Linux video capture interface: v2.00
[    2.557348] pps_core: LinuxPPS API ver. 1 registered
[    2.557380] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giom>
[    2.557451] PTP clock support registered
[    2.559117] Advanced Linux Sound Architecture Driver Initialized.
[    2.559848] Bluetooth: Core ver 2.21
[    2.559906] NET: Registered protocol family 31
[    2.559937] Bluetooth: HCI device and connection manager initialized
[    2.559976] Bluetooth: HCI socket layer initialized
[    2.560010] Bluetooth: L2CAP socket layer initialized
[    2.560065] Bluetooth: SCO socket layer initialized
[    2.560599] NetLabel: Initializing
[    2.560629] NetLabel:  domain hash size = 128
[    2.560657] NetLabel:  protocols = UNLABELED CIPSOv4
[    2.560732] NetLabel:  unlabeled traffic allowed by default
[    2.562041] clocksource: Switched to clocksource arch_sys_counter
[    2.643932] thermal thermal_zone1: power_allocator: sustainable_power will bd
[    2.644301] NET: Registered protocol family 2
[    2.644939] TCP established hash table entries: 32768 (order: 6, 262144 byte)
[    2.645362] TCP bind hash table entries: 32768 (order: 8, 1048576 bytes)
[    2.646469] TCP: Hash tables configured (established 32768 bind 32768)
[    2.646616] UDP hash table entries: 2048 (order: 5, 196608 bytes)
[    2.646837] UDP-Lite hash table entries: 2048 (order: 5, 196608 bytes)
[    2.647376] NET: Registered protocol family 1
[    2.647842] RPC: Registered named UNIX socket transport module.
[    2.647876] RPC: Registered udp transport module.
[    2.647906] RPC: Registered tcp transport module.
[    2.647935] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    2.648987] Trying to unpack rootfs image as initramfs...
[    3.015357] Freeing initrd memory: 6208K
[    3.016258] hw perfevents: enabled with armv8_cortex_a53 PMU driver, 7 counte
[    3.016393] hw perfevents: failed to probe PMU!
[    3.016423] hw perfevents: failed to register PMU devices!
[    3.017951] kvm [1]: 8-bit VMID
[    3.017981] kvm [1]: Hyp mode initialized successfully
[    3.018182] kvm [1]: interrupt-controller@fff20000 IRQ10
[    3.018458] kvm [1]: timer IRQ12
[    3.021779] audit: initializing netlink subsys (disabled)
[    3.021887] audit: type=2000 audit(2.932:1): initialized
[    3.022778] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[    3.032470] VFS: Disk quotas dquot_6.6.0
[    3.032698] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    3.034975] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    3.036545] NFS: Registering the id_resolver key type
[    3.036623] Key type id_resolver registered
[    3.036653] Key type id_legacy registered
[    3.036697] Installing knfsd (copyright (C) 1996 okir@monad.swb.de).
[    3.037584] fuse init (API version 7.23)
[    3.038585] JFS: nTxBlock = 8192, nTxLock = 65536
[    3.044736] SGI XFS with ACLs, security attributes, realtime, no debug enabld
[    3.046967] Key type big_key registered
[    3.047088]
[    3.047088] TEE Core Framework initialization (ver 1:0.1)
[    3.047167] TEE armv7 Driver initialization
[    3.047815] tz_tee_probe: name="armv7sec", id=0, pdev_name="armv7sec.0"
[    3.047853] TEE core: Alloc the misc device "opteearmtz00" (id=0)
[    3.048151] TEE Core: Register the misc device "opteearmtz00" (id=0,minor=62)
[    3.052335] NET: Registered protocol family 38
[    3.052399] Key type asymmetric registered
[    3.052435] Asymmetric key parser 'x509' registered
[    3.052741] Block layer SCSI generic (bsg) driver version 0.4 loaded (major )
[    3.052967] io scheduler noop registered
[    3.053004] io scheduler deadline registered (default)
[    3.053101] io scheduler cfq registered
[    3.055308] phy phy-ff770000.syscon:usb2-phy@e460.0: Failed to get VBUS suppr
[    3.063751] dma-pl330 ff6d0000.dma-controller: Loaded driver for PL330 DMAC-0
[    3.063820] dma-pl330 ff6d0000.dma-controller:       DBUFF-32x8bytes Num_Cha2
[    3.066023] dma-pl330 ff6e0000.dma-controller: Loaded driver for PL330 DMAC-0
[    3.066097] dma-pl330 ff6e0000.dma-controller:       DBUFF-128x8bytes Num_Ch6
[    3.067992] pwm-regulator: supplied by vcc_sys
[    3.068998] Serial: 8250/16550 driver, 5 ports, IRQ sharing disabled
[    3.071207] ff1a0000.serial: ttyS2 at MMIO 0xff1a0000 (irq = 35, base_baud =A
[    3.185889] console [ttyS2] enabled
[    3.187805] [drm] Initialized drm 1.1.0 20060810
[    3.193920] [drm] Rockchip DRM driver version: v1.0.1
[    3.195087] usbcore: registered new interface driver udl
[    3.197781] Unable to detect cache hierarchy for CPU 0
[    3.199485] brd: module loaded
[    3.206207] loop: module loaded
[    3.206556] lkdtm: No crash points registered, enable through debugfs
[    3.209401] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[    3.210025] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[    3.210654] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[    3.211971] m25p80 spi32766.0: gd25q128 (16384 Kbytes)
[    3.212498] 3 ofpart partitions found on MTD device spi32766.0
[    3.213053] Creating 3 MTD partitions on "spi32766.0":
[    3.213537] 0x000000000000-0x0000003f8000 : "loader"
[    3.215196] 0x0000003f8000-0x000000400000 : "env"
[    3.216703] 0x0000007c0000-0x000000800000 : "vendor"
[    3.220816] rk_gmac-dwmac fe300000.ethernet: clock input or output? (input).
[    3.221493] rk_gmac-dwmac fe300000.ethernet: TX delay(0x28).
[    3.222023] rk_gmac-dwmac fe300000.ethernet: RX delay(0x20).
[    3.222585] rk_gmac-dwmac fe300000.ethernet: integrated PHY? (no).
[    3.223408] rk_gmac-dwmac fe300000.ethernet: cannot get clock clk_mac_speed
[    3.224064] rk_gmac-dwmac fe300000.ethernet: clock input from PHY
[    3.229640] rk_gmac-dwmac fe300000.ethernet: init for RGMII
[    3.230339] stmmac - user ID: 0x10, Synopsys ID: 0x35
[    3.230810]  Ring mode enabled
[    3.231121]  DMA HW capability register supported
[    3.231528]  Normal descriptors
[    3.231867]  RX Checksum Offload Engine supported (type 2)
[    3.232387]  TX Checksum insertion supported
[    3.232788]  Wake-Up On Lan supported
[    3.233197]  Enable RX Mitigation via HW Watchdog Timer
[    3.304717] libphy: stmmac: probed
[    3.305079] eth%d: PHY ID 001cc916 at 0 IRQ POLL (stmmac-0:00) active
[    3.305675] eth%d: PHY ID 001cc916 at 1 IRQ POLL (stmmac-0:01)
[    3.308380] Rockchip WiFi SYS interface (V1.00) ...
[    3.308959] usbcore: registered new interface driver cdc_ether
[    3.309576] usbcore: registered new interface driver rndis_host
[    3.312060] rockchip-dwc3 usb@fe800000: failed to get drvdata dwc3
[    3.318834] rockchip-dwc3 usb@fe900000: fail to get drvdata hcd
[    3.321133] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    3.321758] ehci-pci: EHCI PCI platform driver
[    3.322267] ehci-platform: EHCI generic platform driver
[    3.326848] ehci-platform fe3c0000.usb: EHCI Host Controller
[    3.327611] ehci-platform fe3c0000.usb: new USB bus registered, assigned bus1
[    3.328502] ehci-platform fe3c0000.usb: irq 29, io mem 0xfe3c0000
[    3.335058] ehci-platform fe3c0000.usb: USB 2.0 started, EHCI 1.00
[    3.335861] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.336506] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    3.337202] usb usb1: Product: EHCI Host Controller
[    3.337661] usb usb1: Manufacturer: Linux 4.4.132-1075-rockchip-ayufan-ga83bd
[    3.338472] usb usb1: SerialNumber: fe3c0000.usb
[    3.339529] hub 1-0:1.0: USB hub found
[    3.339919] hub 1-0:1.0: 1 port detected
[    3.341161] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    3.341753] ohci-platform: OHCI generic platform driver
[    3.342959] ohci-platform fe3e0000.usb: Generic Platform OHCI controller
[    3.343792] ohci-platform fe3e0000.usb: new USB bus registered, assigned bus2
[    3.344651] ohci-platform fe3e0000.usb: irq 30, io mem 0xfe3e0000
[    3.400264] usb usb2: New USB device found, idVendor=1d6b, idProduct=0001
[    3.400894] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber1
[    3.401592] usb usb2: Product: Generic Platform OHCI controller
[    3.402155] usb usb2: Manufacturer: Linux 4.4.132-1075-rockchip-ayufan-ga83bd
[    3.402951] usb usb2: SerialNumber: fe3e0000.usb
[    3.404013] hub 2-0:1.0: USB hub found
[    3.404461] hub 2-0:1.0: 1 port detected
[    3.407564] usbcore: registered new interface driver iforce
[    3.408179] usbcore: registered new interface driver xpad
[    3.409150] usbcore: registered new interface driver usbtouchscreen
[    3.410159] .. rk pwm remotectl v1.1 init
[    3.410904] input: ff420030.pwm as /devices/platform/ff420030.pwm/input/inpu0
[    3.412750] i2c /dev entries driver
[    4.414104] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x00, state: 1
[    4.414668] fan53555-regulator 0-0040: Failed to get chip ID!
[    4.415292] fan53555-regulator: probe of 0-0040 failed with error -110
[    5.416105] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x00, state: 1
[    5.416662] fan53555-regulator 0-0041: Failed to get chip ID!
[    5.417265] fan53555-regulator: probe of 0-0041 failed with error -110
[    6.418096] rk3x-i2c ff3c0000.i2c: timeout, ipd: 0x00, state: 1
[    6.418654] rk808 0-001b: failed to read the chip id at 0x17
[    6.419240] rk808: probe of 0-001b failed with error -110
[    6.419783] rk3x-i2c ff3c0000.i2c: Initialized RK3xxx I2C bus at ffffff800940
[    6.421380] rk3x-i2c ff110000.i2c: Initialized RK3xxx I2C bus at ffffff800940
[    6.423820] fusb302 4-0022: Can't get property of role, set role to default P
[    6.433090] fusb302 4-0022: port 0 probe success with role ROLE_MODE_DRP, trE
[    6.433954] rk3x-i2c ff3d0000.i2c: Initialized RK3xxx I2C bus at ffffff800940
[    6.436291] IR NEC protocol handler initialized
[    6.436725] IR RC5(x/sz) protocol handler initialized
[    6.437219] IR RC6 protocol handler initialized
[    6.437651] IR JVC protocol handler initialized
[    6.438095] IR Sony protocol handler initialized
[    6.438534] IR SANYO protocol handler initialized
[    6.438981] IR Sharp protocol handler initialized
[    6.439442] IR MCE Keyboard/mouse protocol handler initialized
[    6.439988] IR XMP protocol handler initialized
[    6.440671] usbcore: registered new interface driver uvcvideo
[    6.441218] USB Video Class driver (1.1.1)
[    6.445332] rk_tsadcv2_temp_to_code: Hnvalid cnnversion t`ble: code=1003, te
4,406"1 pnBjB`a`(ph`pLaHDd 400
What is it for an device?
3. RockPro64 v2.1
only keyboard and hdmi is connected nothing else
has nobody any idea what it is and what I can still try ?
(05-12-2019, 06:41 PM)mehdy Wrote: has nobody any idea what it is and what I can still try ?
Try to disconnect the keyboard and display. Only power supply and serial console. And look what is happening?
If still not booting, it worth to check the supply voltages on the board. But it should be done by competent enough man. The board should boot at least without any external devices which are probably may disturb the booting somehow.
  RockPro64 automatically run after power recovery - my solution g2t 1 1,558 05-28-2026, 05:29 PM
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 12,746 06-21-2025, 06:21 AM
Last Post: aleksei
  where to get debian 12 image for rockpro64? heocb 1 4,304 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,638 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 5,355 11-26-2024, 11:08 AM
  Installing Wifi drive for the RockPro64 John45595 0 4,586 02-10-2024, 11:32 PM
Last Post: John45595
  enble boot after power loss/restore dkebler 18 29,773 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 223,527 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,051 09-17-2023, 12:00 AM
Bug Broken boot: What am I missing? mkosarek 1 4,451 09-08-2023, 08:14 AM
