VNC on Rock64 Ambian
on my Rock64 with Ambian, can I use this instruction form Orange Pi Ambian to install VNC?
https://diyprojects.io/armbian-access-re...H96mVW6Pmg
yes
I installed VNC and create user, login as user and so on.
But after typing "vncserver :1" I got following:
You will require a password to access your desktops.
vncserver: Couldn't find "tigervncpasswd" on your PATH.
Please install the tigenvnc-common package, i.e., sudo apt-get install tigenvnc-common.
I tried as well "sudo apt-get install tigenvnc-common.", but I got also an error message
try tigervnc-common not tigenvnc-common
OK, thank you. I'm a little bit further.
Now it seems, that it works, but when I use VNC Viewer from another computer, I can not connect.
On the Rock64 I have following message:
Would you like to enter a view-only password (y/n)? n
/usr/bin/xauth: file /home/rock64/.Xauthority does not exist
New 'localhost:1 (rock64)' desktop at :1 on machine localhost
Starting applications specified in /etc/X11/Xvnc-session
Log file is /home/rock64/.vnc/localhost:1.log
Use xtigervncviewer -SecurityTypes VncAuth -passwd /home/rock64/.vnc/passwd :1 to connect to the VNC server.
Isn't it possible to use the regular VNC viewer?
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 3,395 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 91,576 07-22-2026, 01:47 PM
Last Post: MichaIng
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 19,991 06-27-2026, 02:43 PM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,632 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,796 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 12,763 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,631 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,810 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,707 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 114,173 09-01-2024, 06:05 AM
Last Post: RaymondDay
