ROCKPro64 - power cable?
Question
Howdy,
I run a few rock64 with these cables https://www.pine64.org/?product=1-meter-...ower-cable
Does the H 3.5mm OD/1.35mm ID barrel also fit a ROCKPro64 board power connector?
Cheers.
(04-13-2019, 05:49 AM)skipper Wrote: Howdy,
Cheers.
The plug for the rp64 is bigger than the rock64 and 12v not 5v
thank you
  Powering two disks from RockPro64 some_pinephone_user 3 6,026 02-24-2026, 04:43 PM
Last Post: evilbunny
  TPM module for rockpro64 misha64 0 3,759 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 14,372 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 4,452 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  RP64 Won't Boot After Power Down ColPanic_ 10 19,617 06-27-2023, 07:31 AM
Last Post: dkebler
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 49,109 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 3,934 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 6,565 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 16,895 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 4,577 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
