Rock64 no network
So this is what happened.
I got my new Rock64 yesterday. Been waiting for a month to get this.
I flashed DieptPi and tried to configure it over LAN for first time and it was smooth except at one point there was no display. I tried to reflash the memory card with Dietpi. It started to get the updates for first time and then no display.
I tried to flash OMV on that. When i connect without network it shows no network, which is ok. When i try to connect LAN cable i dont see the rock64 in network.
How can i get this resolved?
I changed the power supply to 5W now and I got network.
But the network is unstable and keeps dropping. How can I fix this?
(04-06-2019, 11:34 PM)ripcord Wrote: I changed the power supply to 5W now and I got network.
Depending on what you have plugged in you may need a 5v 3a power supply
Guess that might be the case. I have plugged in a 4TB external portable HDD USB 3.0.
The connection to that keeps dropping down too. i had no issue with RPi B3+ though. I have ordered a power supply. hope that works out.
thanks.
(04-07-2019, 05:32 AM)ripcord Wrote: Guess that might be the case. I have plugged in a 4TB external portable HDD USB 3.0.
thanks.
What happens to your network if you don't plug the hdd in?
Unless your power supply is up to the job the hdd in the USB 3.00 Port will surely cause you difficulties. No point making comparisons to RPI3+ board. Different beast. Make sure you have enough overhead to power your Rock64 plus peripherals.
thanks.
Haven't tested that. Anyway I have ordered the QC30 based usb adapter which should do the job I guess as i meets the spec.
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 5,448 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 26,141 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 15,557 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 17,067 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,228 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 9,040 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 10,154 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 9,385 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,439 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 4,542 10-07-2022, 07:50 PM
Last Post: rookie_267
