Ethernet --> Causing boot loop
Anyone else with the 2GB module experiencing issues with an endless boot loop whenever Ethernet is plugged in.  I am using a 5v 2amp DC power supply and everything works fine until I plug in ethernet.  I also tried Remix OS / Android Lollipop with the exact same symptoms.  Any help is appreciated as I would be disappointed if I am unable to use the full potential of the board Smile
I heard that Pine64 is working on it- I would look around in the Linux/Android support section. There's some good content around there that may lead you to some resolving of your issue. Others are also having Ethernet issues like you are.
If I've helped you with something, please leave a rating for my responses.
yes i am having the same problem.
I'm using openhabian on Pine64 2G, same problem. Does anyone know any update on this problem?
  Ethernet does not work oceanicmoth 1 1,733 02-06-2026, 11:58 PM
Last Post: zetabeta
  Ethernet port down afert 1 day jeda 0 2,648 11-12-2022, 06:48 AM
Last Post: jeda
  Boot needs up to 7 minutes on Ubuntu 16.04 JulianM 3 9,146 03-15-2017, 05:46 AM
Last Post: pfeerick
  GbE Ethernet Port Issue Data Gathering Statistics Intel MarkHaysHarris777 19 39,159 01-17-2017, 01:17 AM
Last Post: DrunkTank
  What will it take to get the Ethernet port working? clarkss12 10 33,799 10-17-2016, 03:42 PM
Last Post: waldo
  Ethernet Slow Download Ascotg 89 185,581 09-08-2016, 01:50 PM
Last Post: MarkHaysHarris777
  Pine64+ 1GB Ethernet Port spec ecotack 13 26,582 08-20-2016, 09:28 PM
Last Post: pfeerick
  If you have had difficulty with the GbE ethernet please take the poll MarkHaysHarris777 0 3,976 08-17-2016, 05:44 PM
  Ethernet works on Arch Linux. Nothing elese pfunk237 4 10,127 07-23-2016, 03:07 PM
Last Post: SuperArmySoldiers
