Ethernet does not work
I'm using the pine a64 with 512mb of ram. i used like 5 different operating systems and all of them couldn't detect my Ethernet connection. what could be detected was a USB Ethernet dongle, however none of the operating systems had drivers for it. I'm pretty sure there's something broken on the board and wanted advice on confirming that and what to do next. thank you
(02-06-2026, 07:19 PM)oceanicmoth Wrote: I'm using the pine a64 with 512mb of ram. i used like 5 different operating systems and all of them couldn't detect my Ethernet connection. what could be detected was a USB Ethernet dongle, however none of the operating systems had drivers for it. I'm pretty sure there's something broken on the board and wanted advice on confirming that and what to do next. thank you
i got a weird feeling that dongle is broken.
you could use command "lsusb" before and after inserting dongle to troubleshoot it. (may require package installation, probably "usbutils".) also "ip address" shows something, if usb device is detected.
  Ethernet port down afert 1 day jeda 0 2,601 11-12-2022, 06:48 AM
Last Post: jeda
  Ethernet --> Causing boot loop podtofs 3 8,596 05-16-2017, 03:41 AM
Last Post: m17
  GbE Ethernet Port Issue Data Gathering Statistics Intel MarkHaysHarris777 19 38,613 01-17-2017, 01:17 AM
Last Post: DrunkTank
  What will it take to get the Ethernet port working? clarkss12 10 33,415 10-17-2016, 03:42 PM
Last Post: waldo
  Ethernet Slow Download Ascotg 89 182,916 09-08-2016, 01:50 PM
Last Post: MarkHaysHarris777
  Pine64+ 1GB Ethernet Port spec ecotack 13 26,217 08-20-2016, 09:28 PM
Last Post: pfeerick
  If you have had difficulty with the GbE ethernet please take the poll MarkHaysHarris777 0 3,906 08-17-2016, 05:44 PM
  Ethernet works on Arch Linux. Nothing elese pfunk237 4 10,018 07-23-2016, 03:07 PM
Last Post: SuperArmySoldiers
