No USB Power (ROCK64+ARMBIAN 5.7)
Question
Armbianmonitor:
http://ix.io/1DAn
Hello, can someone help me with my problem.
I have a ROCK64 with 4GB of RAM and an ARMBIAN 5.75 stable Ubuntu 18.04.2 LTS 4.4.174-rockchip64, installed.
My issue come with usb ports, from the three USB of the this device only works two: one 2.0 and 3.0. And when i have a disk connected towards usb 3.0 i have issues with port usb 2.0, it doesn't work well and I end up disconnecting the USB 3.0 to can work with my device connected towards USB 2.0 so I assume that the current power on the USB port is having issues or it's not working well.
Anybody an idea?
thanks!
Typical power supply issues. You can either try a different power supply to rule this in or out or use a meter to measure the current draw on the power supply when all USB ports are in use.
(03-15-2019, 07:36 AM)Rocklobster Wrote: Typical power supply issues. You can either try a different power supply to rule this in or out or use a meter to measure the current draw on the power supply when all USB ports are in use.
any other options or ideas?
is there any way to check current power of each usb from OS?
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,226 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 4,811 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 96,393 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,032 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,436 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,444 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,932 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,105 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,999 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 117,684 09-01-2024, 06:05 AM
Last Post: RaymondDay
