NAS Case and two hard drives?
I finally got around to putting together my RockPro64 and the NAS case.
I have the PIne64 power supply (12V/5A) as well as 2 8TB Seagate Ironwolf NAS drives.
When I booted from Armbian, NextcloudPI, and Ayufan's OMV image on an EMMC card, all is fine.
Once I added the 2 Drives, nothing...
Reimaged the EMMC and tried with 1 Drive, nothing...
Reimaged the EMMC again and tried with a WD 4TB Red NAS drive, nothing...
Reimaged again and tried with just the EMMC card and all is fine.
Guessing the Hard Drives I have are drawing too much power for the stock Pine64 power supply. Is it possible to put in a higher amp power supply? Maybe 6 or 7 amps?
Thoughts or suggestions?
Thanks!
Sent from my iPad using Tapatalk
I got my case and I use two old harddisks to test it, it seems ok.
I use a 12V/5A power supply.
I bought two WD 4TB Red NAS drive and want to build a raid system. it's on the way now.
(03-11-2019, 06:15 AM)chengjianwen Wrote: I got my case and I use two old harddisks to test it, it seems ok.
Thanks, Good to know.  I'll try again with some other hard drives and see what I come up with.
the disks arrived yesterday and I installed successfully.
the ayufan's image can't recoginized the disks, so I replaced the kernel with mrfixit2001's.
I use openmediavault to create a raid 1, it use about 5-6 hours to created it.
to set fan work, I installed ats. it seems worked good.
I trans a file with ssh, the speed is ahout 60-70MB/s, I don't kown is there any method to make it more fast.
Over SMB? you may wish to try some tweaks, these at the very least:
min receivefile size = 16384 write cache size = 524288 getwd cache = yes
I use ssh(scp) from my Macmini host directly, and there is no swich/router.
board is Rockpro64/2G.
Hi! Quick question: Did you just build mrfixit2001's kernel from source from here? https://github.com/mrfixit2001/rockchip-kernel
Hi @chengjianwen
I am thinking about switching from a Synology 713+ NAS to a Pine64 RockPro4G NAS
My 713+ Synology uses about 40Watt's constant incl. 2 WD RED 3TB HDD's.
Can you tell me about your power consumption with the 2 HDD's ?
Thx!
Gr. Hemertje
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,264 09-17-2023, 12:00 AM
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 4,216 01-27-2023, 07:43 PM
Last Post: Spater
  Troubleshooting RockPro64 + Roshambo case SSD problems necoc.yaotl 1 5,187 11-30-2020, 11:10 PM
Last Post: necoc.yaotl
  Rockpro64 Case WIP xbcsmith 1 5,882 09-26-2020, 12:46 AM
Last Post: zer0sig
  Rockpro64 Case WIP xbcsmith 0 3,259 01-26-2020, 05:02 PM
Last Post: xbcsmith
  RockPro64 & Roshambo Case Gouki 2 7,696 01-26-2020, 12:57 AM
Last Post: EagleFlyFree
Question How to automatically reboot rockpro64 in case it shutdown abruptly ? seaurchin 2 6,462 11-25-2019, 08:46 AM
Photo RockPro64 Case 2x3.5" HDDs and 2x2.5 HDDs Luke 48 173,424 10-17-2019, 11:58 AM
Last Post: Tim Jones
  Basic question on the Nas case of the rockPro Slam 1 5,446 01-23-2019, 08:04 AM
Last Post: Slam
  NAS Box - fdisk not showing hard-drives w/pcie sata card dkebler 0 3,093 10-12-2018, 12:30 PM
Last Post: dkebler
