Rock64 generally unstable?
For weeks I have been trying to get my Rock64 4GB into a stable system state.
It does not work properly and there are many problems with it. I tried a lot for weeks until I realized that it wasn't the operating system or a program. Even when idle on a freshly installed system (stretch-minimal-rock64-0.7.11-1075-arm64.img), error messages appear on the console after some time and the system hangs.
Copying large files reproducibly brings the system to a standstill. I am using an original power supply, the CPU temperature is not higher than 55°C.Now I suspect a hardware problem.
- Is there a program to check the hardware reliably?
- What else can I try?
Regards, Sputnik
Message from syslogd@nextcloudpi at Feb 25 20:39:10 ...
 kernel:[275628.666184] 3f60: 0000000000000001 0000000000000001 0000007f99e53d88 0000007f99e574c8
 kernel:[275628.678344] 3f80: 0000007f99e56000 0000000000000001 0000007f99e58a20 0000000000000000
 kernel:[275628.690489] 3fa0: 0000000000000000 0000007ff3c3dc20 0000007f99d46300 0000007ff3c3dc20
 kernel:[275628.702503] 3fc0: 0000007f99dafa7c 0000000060000000 0000000000000000 000000000000005e
 kernel:[275628.714493] 3fe0: 0000000000000000 0000000000000000 0000000000000000 000000000000000
I am not a specialist, but you may check the loaded module with lsmod and modinfo <module>
another thing : avoid touching the gpio when you manipulate rock64
LMM.
you can also check the entire kernel buffered traces with dmesg
Did you try Armbian too?
https://www.armbian.com/rock64/
What is all connected to the Rock64?
What do you mean with hangs? Is it just for some time it stops working? Or does it crash completely?
(02-27-2019, 10:48 AM)NicoD Wrote: Did you try Armbian too?
Thanks for the clues.
Nothing is connected externally to the Rock64 and still the system sometimes stops. You can't enter anything on the console anymore.
I'm going to try Armbian now.
Thank you!
Armbian been running nearly a year here with no problems and supports most of the hardware and peripherals I've thrown at it. You might have problems with some of the more exotic distros and will need a little kernel knowledge to tailor them to suit your needs.
I just got a new rock 64 my setiathome has computational errors. This is the only system it happens with. Does not matter which distro. Does not matter if 1.3 ghz or 1.51 ghz.
(02-26-2019, 02:31 AM)Sputnik Wrote: - What else can I try?
When I played with overclocking, this one did quite a good stability test for CPU/RAM: https://www.mersenne.org/download/
If every stress mode is fine for 8-10 hours — system may be considered as stable. Usually it stopped with an error in a 5-10 minutes.
Causes high load, so watch the chip temperature!
(03-04-2019, 12:48 PM)Rocklobster Wrote: Armbian been running nearly a year here with no problems and supports most of the hardware and peripherals I've thrown at it. You might have problems with some of the more exotic distros and will need a little kernel knowledge to tailor them to suit your needs.
I am having problems with my rock64 as well. Running armbian stretch. Maybe I should try armbian ubuntu. What distro do you run?
Armbian Bionic downloaded from here https://www.armbian.com/rock64/
Yes, that is where I got the stretch. Been running bionic now for a few days, but still trouble. Opened support ticket.
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 1,217 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 11,242 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 7,226 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 6,316 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 807 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 2,874 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 4,378 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 3,106 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 1,113 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 1,306 10-07-2022, 07:50 PM
Last Post: rookie_267
