Pinebook Pro NVMe Question
I learned about the upcoming Pinebook Pro from an article in Forbes today: https://goo.gl/ZQUbyb
The part that really caught my attention was "an unpopulated NVMe slot."
IF someone populated the NVMe slot with a drive, would the Pinebook Pro use the built-in eMMC flash storage for startup and core OS tasks, using the NVMe drive for primary storage?
(01-31-2019, 08:27 AM)Selden Wrote: I learned about the upcoming Pinebook Pro from an article in Forbes today: https://goo.gl/ZQUbyb
To my knowledge, PCIe (which is the interface used for NVMe) isn't bootable at this time in either the BSP or mainline kernel. So, presently, NVMe drives can only be used as storage. This may however change in time.
The SD Card slot would be a viable boot device tho correct?
(01-31-2019, 12:53 PM)DennyL Wrote: The SD Card slot would be a viable boot device tho correct?
Yes, SD is bootable
Thanks, Luke, that's what I expected. I'm not interested in booting from the NVMe drive, but from the eMMC, which I assume can be partitioned, with a different distro in each partition, using GRUB at boot to select. With a 64 Gb eMMC flash storage, space might get tight, but with 128 Gb, not so much, as long as the NVMe is recognized by any of them. Plan B would be to boot from sd card, as Denny suggests. Pre-release spec isn't clear: will the Pinebook Pro have a SDHC slot or a microSD slot? Doesn't really matter, as I have a 128 Gb microSD, which can slot into a SDHC adapter.
At this point, with the Pinebook Pro not yet released, and my not having made a purchase decision, this is a hypothetical question, but I am obsessive about researching things before investing -- even for a $199 laptop.
i saw in an article that there will be 128 gb eMMC option for registered users, is that correct? in that case i could fit two and more partitions
(03-25-2019, 12:21 AM)favio Wrote: i saw in an article that there will be 128 gb eMMC option for registered users, is that correct? in that case i could fit two and more partitions
Correct.
  default login & password, Pinebook Pro? kiloseven 1 1,763 12-11-2025, 12:11 AM
Last Post: kiloseven
  Running Linux on Pinebook Pro with External Monitor Twers1962 2 3,553 03-25-2025, 11:10 PM
Last Post: Dendrocalamus64
  Pinebook Pro vs Pinetab2 Lotech 5 6,654 12-10-2024, 09:10 PM
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 3 6,840 12-10-2024, 07:23 PM
  Please Help: Bricked Pinebook Pro with Keyboard Update dumbguywhobrokehiscomputer 3 8,195 07-14-2021, 02:49 PM
  Java on Manjaro ARM Pinebook Pro gulagpyromaniac 3 7,855 05-25-2021, 11:05 AM
  Setup My Pinebook 64 and Lost Password jersdayoff 5 12,902 05-01-2021, 10:29 PM
  How to boot from SD card on pinebook pro linux123 3 10,414 12-02-2020, 10:29 AM
Last Post: linux123
  Pinebook Pro- configuration aborts setting keyboard layout scroall 10 21,247 10-30-2020, 11:58 AM
Last Post: scroall
  Changing locale on Pinebook Pro Perl6_user 5 12,255 09-16-2020, 05:13 PM
Last Post: guava
