Only ttyS2 working with rockpro64.
I am using ubuntu18 minimal LXDE image with my rockpro64.
I am using ttyS2 for UART communication. Have two doubts-
1) When i use 1500000 Buadrate, then it works fine. But when i change its baudrate to 115200 then after some time, my UART gives unexpected symbols but not correct data. So is ttyS2 should be used with 1500000 baudrate only?
2) I wanted to use ttyS4(UART4), But it is not working. Can i enable this?
Thanks.
Please update as my important task is pending on same.
Can't i use ttsS2 with different buadrate such as 115200? I am getting garbage data in this baudrate.
Thanks.
  RockPro64 automatically run after power recovery - my solution g2t 1 567 05-28-2026, 05:29 PM
  where to get debian 12 image for rockpro64? heocb 1 3,676 05-18-2025, 02:30 PM
Last Post: Dendrocalamus64
  Use android on RockPro64 without a LCD screen ? john_nash 0 3,156 03-28-2025, 11:15 PM
Last Post: john_nash
  How to use ROCKPro64 PCI-e X4 to M.2/NGFF NVMe SSD Interface Card jykeith123 1 4,672 11-26-2024, 11:08 AM
  power button not working Vista8720 0 2,836 05-07-2024, 11:26 PM
Last Post: Vista8720
  Installing Wifi drive for the RockPro64 John45595 0 4,071 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 5,346 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,262 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 12,316 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 4,607 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
