Custom Kernel for ROCK64
Dear Pine Users,
thank you for providing the discussion group for the ROCK64 platform. I tried to use a custom compiled kernel for several days now. Unfortunately, every attempt results in a system that does not boot.
The most promising way seemed to me the following with a newly installed distribution via Etcher. I took the Ubuntu 18.4. Desktop variant. Then I have executed the following commands on-board:
sudo dpkg-reconfigure keyboard-configuration
sudo dpkg-reconfigure tzdata
sudo apt update
sudo apt upgrade
sudo apt -y install cmake build-essential python-minimal bison flex bc libssl-dev libncurses5-dev lzop make u-boot-tools binfmt-support ninja-build libfl-dev python python2.7 swig libpython-dev flash-kernel
sudo reboot
mkdir workspace
cd workspace
git clone https://github.com/ayufan-rock64/linux-m...kernel.git
cd linux-mainline-kernel
make rockchip_linux_defconfig
make -j4
sudo make modules_install
sudo make dtbs_install
sudo make install
After this, the platform will not reboot. I just get a black screen. The LEDs of the ROCK64 just light up a few seconds. Then only the green LED remains.
I have checked the file /boot/extlinux/extlinux.conf
If I remove the entries for the newly installed kernel, the platform boots with the old kernel again (4.4.).
By the way, why do I have /boot/extlinux/extlinux.conf and /boot/efi/extlinux/extlinux.conf?
I hope, you can give me a hint, what is missing or how I can debug this issue, since I do not see any output, also not from u-boot.
Best regards,
   Stefan May
I'm also interested in this issue. What steps are required to make a custom kernel image bootable on a rockpro64?
Meanwhile, I solved my problem by myself. The kernel source snapshots at github are not all bootable. I tried to use the 4.20. kernel but with no success. Since I have no serial console, I was not able to figure out what was going wrong with the new kernel.
The 4.19. kernel, I could boot, but with no HDMI output. In the end I took the version 4.4.132-1075-rockchip-ayufan from [url=https://github.com/ayufan-rock64/linux-kernel/releases/tag/4.4.132-1075-rockchip-ayufan][/url]https://github.com/ayufan-rock64/linux-kernel/releases
You can download this version here: https://github.com/ayufan-rock64/linux-k...fan.tar.gz
I took the configuration from /proc and modified the config file to my needs (activated CAN interface).
Please let me know, if you manage to boot any newer kernel.
  MRAA Rock64 support jbize 2 5,691 07-09-2022, 04:40 AM
Last Post: igorp
  Rock64 with Debian netinst usb Bloris 6 15,169 12-03-2019, 12:37 PM
Last Post: madalin
  The differences between Rock64 and RockPro64 phamoanh 1 7,589 06-12-2019, 10:44 PM
Last Post: evilbunny
Bug Rock64 Login lpninja 1 7,356 10-04-2018, 12:02 AM
  Rock64 suitable for headless TVHeadend install? elsmandino 3 10,339 06-26-2018, 11:37 AM
Last Post: Luke
  Will the Rock64 work as a mobile data storage device? Kennetht 1 5,293 03-29-2018, 10:07 AM
Last Post: xalius
  Laptop as a bridge for Rock64's internet connection dmitrymyadzelets 3 8,795 03-28-2018, 05:24 AM
Last Post: dmitrymyadzelets
  Rock64 OS eMMC boot ProfessionalDreamer 2 8,181 02-20-2018, 08:44 PM
Last Post: ProfessionalDreamer
  opencv on rock64 bendiro 4 10,712 02-07-2018, 05:08 AM
Last Post: xalius
  Kodi on Rock64 board cenguix 2 11,970 02-02-2018, 03:05 PM
Last Post: stuartiannaylor
