Can't connect to wifi on a Rock64
I'm trying to set up a Rock64 to connect to wifi using a Panda PAU09 USB wifi adapter.  The adapter is mounted in a fixed location, and when connected to my laptop running Ubuntu Bionic, I am able to easily connect to my own wifi network, as well as my school's secure network and their guest network using NetworkManager.  However, when I connect the adapter to the Rock64, I am unable to connect to any wifi networks, in spite of seeing them listed when I do a network scan.  I have tried this using Armbian Stretch and Bionic images, and also using ayufan's Bionic image.  When using nmcli to bring up the connection, I usually receive the error message "The Wi-Fi network could not be found".  However, scanning for networks usually shows the network I am attempting to connect to with good signal strength.  Other times, the connection will actually "succeed" but I won't be able to communicate over it and then the connection just goes down within seconds.
Any ideas on how I could make this work?
(12-18-2018, 07:14 PM)SuperSaiyanCaleb Wrote: I'm trying to set up a Rock64 to connect to wifi using a Panda PAU09 USB wifi adapter.  The adapter is mounted in a fixed location, and when connected to my laptop running Ubuntu Bionic, I am able to easily connect to my own wifi network, as well as my school's secure network and their guest network using NetworkManager.  However, when I connect the adapter to the Rock64, I am unable to connect to any wifi networks, in spite of seeing them listed when I do a network scan.  I have tried this using Armbian Stretch and Bionic images, and also using ayufan's Bionic image.  When using nmcli to bring up the connection, I usually receive the error message "The Wi-Fi network could not be found".  However, scanning for networks usually shows the network I am attempting to connect to with good signal strength.  Other times, the connection will actually "succeed" but I won't be able to communicate over it and then the connection just goes down within seconds.
Quick google of your adaptor and it seems to be an 802.11ac device which aren't included in the linux kernel. This means most if not all distros don't include drivers for it.
At a quick glance I wasn't able to find linux drivers from the manufacturer's website, nor the chipset it uses
802.11n, actually.  According to this, it makes use of the Ralink RT5572.  The fact that NetworkManager detects it and is able to scan for networks with it suggested to me that drivers are indeed included in the default configurations of the images I tried, but I'm all ears if there's something else I should install.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 17,370 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 566 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 4,945 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 10,938 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 2,791 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 2,907 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,095 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 80,500 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 105,759 09-01-2024, 06:05 AM
  Rock64 v2 - did not work song / audio sqw200zu 2 5,458 03-14-2024, 03:09 AM
