Rock64: LAMP + WordPress + Let’s Encrypt SSL
Information
Hi guys,
I would like to share with you some posts that I wrote about how to mount your web server in your Rock64.
I created my own blog using Wordpress and hosting everything on my Rock64.
I'm using ARMBIAN as OS and it is perfect as a server.
If you want to take a look to the post please visit the blog:
https://devandadmin.com/rock64-lamp-word...sl-part-1/
Nice, don't want it moved to the tutorials section ? Also, you could link it in wiki projects section in the correct place.
(11-28-2018, 11:38 AM)Luke Wrote: Nice, don't want it moved to the tutorials section ? Also, you could link it in wiki projects section in the correct place.
Sure, just tell me what to do please.
You can log into wiki using your forum credentials. I've included a short explanation how-to add stuff at the beginning of the section I link below. Thanks:
http://wiki.pine64.org/index.php/Project
(11-28-2018, 02:45 PM)Luke Wrote: You can log into wiki using your forum credentials. I've included a short explanation how-to add stuff at the beginning of the section I link below. Thanks:
Hi Luke,
I was looking the Wiki section because I want to add my project to the Wiki.
I found something bad,
There is one link on the "Server projects" pointing to a porn site
http://wiki.pine64.org/index.php/Project...r_Projects
The last row of that table (server projects), the author is "Lenny Raposso".
I did add my own record to the table.
Thank you for letting me know - if you haven't already, I'll remove it. I removed both entries from the author.
(11-28-2018, 10:48 AM)cristobalhdez Wrote: Hi guys,
I kinda achieved the same with dockers:
https://hub.docker.com/r/lsioarmhf/mariadb-aarch64/
https://hub.docker.com/r/arm64v8/wordpress/
I didnt add letsencrypt, i should, but im doing that at a later time but there is:
https://hub.docker.com/r/lsioarmhf/letsencrypt/
that should work but im wondering if there is any serious difference other than simplifying the whole setting...i can post the docker create i used if you or anyone is interested...
btw im not trying to be a d**k, just wanted to share a simpler method and ask if there is any problem doing it my way...
PS: After a lot of research i have an omv install working with wordpress-madiadb and transmission, pihole, syncthing, radicale, i can add all the explanation for every option and how to make everything interact and some basic of the settings on every docker and make a guide sort of here on the site i guess (i also have set on it radarr+sonarr+lidarr+jackett but i can omit those if you guys think that is risky)
PS2: i can also add my notes on how to make this all work from a single HDD and without microsd or emmc at all...i guess...
  rAudio for Rock64 V2 shinzuka 9 1,123 06-05-2026, 06:22 AM
Last Post: shinzuka
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 12 18,190 03-07-2026, 11:04 AM
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 920 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 5,662 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,570 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,061 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,233 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,287 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 84,958 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 109,043 09-01-2024, 06:05 AM
