Armbian - Xenial Desktop (Pinebook)
#51
Armbian
Stretch with kernel 4.19.y (Bionic builds lack web-gl support within Chromium for unknown reason)
https://www.armbian.com/pinebook-a64/ (admin, please don't link directly to the images yet since URL will be changed once it's released)
Images are in a developer preview state, upgrades are locked down, ... but most critical functions (except suspend/resume) are working which means build is usable and (need more testing) stable. It's faster and cleaner - no proprietary Allwinner junk - than legacy builds, most of existing compilations ... Mainly based on @anarsoul kernel work + a bunch of our generic A64, kernel and userspace fixes and adjustments.
One image for both Pinebooks!
working: DVFS, battery and brightness control, 3D MALI with open source Lima drivers, Chromium web-dl enabled, profile cached, ...
not enabled or not tested: BT, suspend/resume, sound
There is still a lot of work to get to the pitch perfect state. Thank you for your support!
#52
(11-22-2018, 01:56 PM)igorp Wrote: Armbian
Very nice, Armbian + 4.19 kernel :Smile
Trying it!
#53
Very nice.
#54
(11-22-2018, 01:56 PM)igorp Wrote: There is still a lot of work to get to the pitch perfect state. Thank you for your support!
My favourite ARM Linux distribution on my Pinebook! I already managed to do more with it in an hour than I could with the KDE Neon since I got it. I can't spare much but I threw a little your way. As always the work on Armbian, and all the information you put online is greatly appreciated.
#55
(11-22-2018, 01:56 PM)igorp Wrote: One image for both Pinebooks!
Is video acceleration really working?
Is see 100% CPU load when I long press space )
#56
Using stretch, I have no audio on the internal speaker. Any fix?
#57
(12-10-2018, 08:30 AM)krsmit0 Wrote: Using stretch, I have no audio on the internal speaker.  Any fix?
Known problem (for now). It's because Pinebook audio driver is not yet mainlined in 4.19 kernel. It's expected to be fixed in 4.20 kernel (perhaps, it would be released by the end of month).
#58
Who told you that? It is not implemented and there is nobody who will implement this anytime soon. For video acceleration capabilities, you need to stick to old kernel builds for now. Currently we only support Pinebook 720p with this "beautiful" old kernel. 3D acceleration/MALI/LIMA has nothing to do with video acceleration.
We will stay at and port things to 4.19.y which is LTS and our first non-beta build will be receiving updates until everything will be working. No reimaging needed.
#59
You can get audio to work if you unmute it in alsamixer. Don't have a PB with armbian on hand, but this was the case on manjaro and arch running same kernel ...
#60
this did not work, thanks.
  DietPi OS for Pinebook MichaIng 5 17,155 07-28-2026, 08:02 PM
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 4 14,609 05-18-2026, 02:11 PM
  Armbian broken sometime in the last few months acruhl 4 6,432 05-29-2024, 10:44 PM
Last Post: acruhl
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 104,386 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 5,935 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,478 07-10-2023, 07:44 AM
  Change console resolution (Armbian/bookworm) jcgraybill 1 7,393 06-22-2023, 01:31 PM
Last Post: jcgraybill
  Pinebook no longer boots rjtanner 12 16,753 04-13-2023, 01:09 PM
  Armbian 22.02 Release Announcement TRS-80 0 4,772 02-28-2022, 05:02 PM
Last Post: TRS-80
  Stock Debian on original Pinebook moonwalkers 1 8,436 01-29-2022, 10:37 PM
Last Post: cel
