Dimmed screen too much in plasma
hello, I've recently received my Pinebook with the 1080 screen. all was going well until I dimmed the screen too far in the plasma settings window. Now my screen is black when it is on. during boot I see things as the boot sequence clearly is not affected by the plasma setting. How can I fix this without being able to see anything? This is with the original install.
If the slider goes all the way to the left does plasma actually go black or is there some weakness with my screen in this Pinebook?
(11-08-2018, 09:49 PM)boballen55 Wrote: hello, I've recently received my Pinebook with the 1080 screen. all was going well until I dimmed the screen too far in the plasma settings window. Now my screen is black when it is on. during boot I see things as the boot sequence clearly is not affected by the plasma setting. How can I fix this without being able to see anything? This is with the original install.
Nice, the forum suggested a post that solved my issue. I didn't use "backlight" as a keyword so I didn't find it initially. A flashlight in a dark room lets you see the screen just enough to fix the resolution. it did require a restart for the setting to actually work... This is solved.
  Plasma-wayland on Manjaro tophneal 2 10,053 09-01-2020, 06:48 AM
  pinebook black screen when booting with "different power mode than last used" penzoiders 12 32,613 04-27-2020, 06:27 AM
  Blank Screen on Boot MECZero 4 12,214 05-12-2019, 11:54 AM
  How to Configure Screen Brightness in mate on pinebook via terinal? shirman 6 16,437 12-02-2018, 05:37 AM
Last Post: mikee3000
  Pinebook Ubuntu XFCE screen resolution options Fox7799 2 7,468 12-01-2018, 06:05 PM
Last Post: Fox7799
  Netflix on KDE Plasma SoccerCrazed 0 3,633 11-16-2018, 10:11 AM
Last Post: SoccerCrazed
  Screen backlight accidentally zero % boubik 5 11,810 09-10-2017, 01:14 PM
Last Post: boubik
