KDE Install on new Pinebook, howto?
So what now? I have downloaded and etched the latest KDE image on a micro SD.
Now I put the card into the Pinebook and that thing boots into a nice Linux KDE Desktop.
Now, how do I move that image to the eMMC?
Bear in mind, the eMMC is empty and unformatted, I only have the KDE on the micro SD....
(11-08-2018, 06:40 AM)Corkonian Wrote: So what now? I have downloaded and etched the latest KDE image on a micro SD.
Everything you need is in the wiki - NOOB section. But I'll make it easy for you: option 1) download the image you want to your installation running from SD. DD the downloaded image  to the eMMC from within the environment on SD as you would on any other computer to any other media; option 2) use FEL SD card OR open up the Pinebook and use the FEL button + A-to-A cable.
Been there. Downloaded image and etched.
a) KDE Neon image doesn't show up as microSD to eMMC - which is akward.
b) No other cables or adapters available
c) sudo ./Pine64_install_to_eMMC.sh won't work as I only have an 8GB microSD at hand
I am not sure you understood me, read the Flashing to eMMC from a SD Boot (Allwinner A64 Devices) in NOOB section.
On the latest KDE image /usr/local/sbin is empty. No script there. No way to do a pine64_install_to_eMMC
1) Boot from SD; 2) Open browser and download the image you want to flash; 3) DD to eMMC 4) take SD out; 5) boot from eMMC.
Not sure if I can make it clearer
(11-08-2018, 11:31 AM)Luke Wrote: 1) Boot from SD; 2) Open browser and download the image you want to flash; 3) DD to eMMC 4) take SD out; 5) boot from eMMC.
As I said in my original post: only 8 GB SD available.
Can't make it any clearer, sorry.
This is what I am going to try. I am in the process so YMMV
Use this info to figure out which mirror downloads the fastest https://files.kde.org/neon/images/pinebo...mirrorlist
IMAGE_URL=https://files.kde.org/neon/images/pinebook-remix-nonfree/useredition/20181028-1500/neon-pinebook-remix-useredition-20181028-1500-arm64-1080p.img.gz
Booted from the sd card.
umount -f /dev/mmcblk1*
curl -L -f "$IMAGE_URL" | gzip -d | dd bs=30M of=/dev/mmcblk1
sync
Also would like to point out that pine64_install_to_eMMC.sh is an ayufan script. It will not work with the KDE Neon remix
Update this worked for me. (I didn't like the dd from curl as I wanted to verify the chksum...)
curl -kO http://mirror.cc.columbia.edu/pub/softwa...80p.img.gz
sha256sum neon-pinebook-remix-useredition-20181028-1500-arm64-1080p.img.gz
cat neon-pinebook-remix-useredition-20181028-1500-arm64-1080p.img.gz | gzip -d | dd bs=24M of=/dev/mmcblk1
* remove sd card and reboot
Corkonian, 8GB is plenty for stretch minimal ...
xbcsmith, that is exactly what I meant.
  DietPi OS for Pinebook MichaIng 5 16,954 07-28-2026, 08:02 PM
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 4 14,514 05-18-2026, 02:11 PM
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 103,485 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 5,864 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,424 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 16,551 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 8,371 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 10,649 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 11,357 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 8,456 01-20-2021, 11:18 AM
