Arch Linux on Rockpro64
Do you guys had any success installing Arch Linux ARM on Rockpro64? Ayufan's debian is working fine for me but for Arch Linux ARM, it didn't even boot the OS.
I followed installation instructions on this page, but hadn't got any luck.
(11-06-2018, 12:49 AM)ali Wrote: Do you guys had any success installing Arch Linux ARM on Rockpro64? Ayufan's debian is working fine for me but for Arch Linux ARM, it didn't even boot the OS.
Hopefully you were using RockPro64 uboot & DTB? These guys seemed to be OK a couple of months back.
Installing Arch Linux ARM as described on the Rock64 page you link to, is not available for the RockPro64 (yet). There are alternatives to get a working Arch disto. All rely on installing one of the existing images and removing all but the kernel (boot folder) and u-boot. I followed these instructions and got a pretty stable set-up (NAS mostly):
$ cat /etc/os-release
NAME="Arch Linux ARM"
ID=archarm
ID_LIKE=arch
PRETTY_NAME="Arch Linux ARM"
ANSI_COLOR="0;36"
HOME_URL="http://archlinuxarm.org/"
SUPPORT_URL="https://archlinuxarm.org/forum"
BUG_REPORT_URL="https://github.com/archlinuxarm/PKGBUILDs/issues"
and
$ uptime
21:19:28 up 42 days, 30 min,  1 user,  load average: 0.10, 0.09, 0.08
(11-06-2018, 01:48 PM)dukla2000 Wrote: Hopefully you were using RockPro64 uboot & DTB? These guys seemed to be OK a couple of months back.
(11-06-2018, 03:38 PM)Yoast Wrote: Installing Arch Linux ARM as described on the Rock64 page you link to, is not available for the RockPro64 (yet). There are alternatives to get a working Arch disto. All rely on installing one of the existing images and removing all but the kernel (boot folder) and u-boot. I followed these instructions and got a pretty stable set-up (NAS mostly):
ID=archarm
ID_LIKE=arch
ANSI_COLOR="0;36"
and
$ uptime
The HDMI port isn't going to work nicely with vanilla Arch, right? I guess I should stick with ayufan's Debian... at least for now
HDMI did work out of the box last time I used Arch on RK3399. (kernel from Debian)
(11-08-2018, 12:16 PM)elatllat Wrote: HDMI did work out of the box last time I used Arch on RK3399. (kernel from Debian)
have you managed HDMI to work? If it worked, how?
"out of the box" means it just worked
(11-08-2018, 01:13 PM)elatllat Wrote: "out of the box" means it just worked
ouch my bad... I misread your post. Thanks! I will try to install Arch then.
Right now I'm using Arch on my rockpro64 to post this.
How to get hardware acceleration working? Does the driver exist for linux?
But HDMI didn't work if I use vanilla archlinux ARM kernel
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 12 19,615 06-27-2026, 04:09 PM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 164,119 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 2,668 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 4,357 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 9,168 10-29-2023, 04:43 PM
Last Post: brotherj4mes
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 5,117 09-22-2023, 04:27 AM
Last Post: diederik
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 40,039 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 122,095 08-11-2023, 11:13 AM
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 7,109 07-14-2023, 04:22 AM
Last Post: hunderteins
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,045 05-21-2023, 11:34 PM
Last Post: shpark
