DietPi for the RockPro64
DietPi for the RockPro64 is now available.
You can download it directly from DietPi's website
[Image: cbuceip.png]
I'll try this out this evening.
Interestingly, due to which the Odroid-N1 has higher performance in the rating DietPi?
(09-11-2018, 01:37 AM)romtorwator Wrote: Interestingly, due to which the Odroid-N1 has higher performance in the rating DietPi?
First of all, the Odroid-N1 is no more. Secondly, regarding file performance, probably because their eMMC modules are faster (than original/ older) than PINE64 eMMC modules.
As for the CPU, DietPi uses ayufan's kernel and for the time being ayufan chose "stability over performance" - so the rk3399 is clocked a little slower (1.8ghz).
I had a look at this last night. Even though it says GPU features (e.g. Kodi, Desktop) don't work, you can get to the desktop if you tweak the xserver config a bit. It looks like it still needs work though. Youtube and similar websites weren't working. I tried experimenting with manually installing some of ayufan's libmali stuff but that didn't help.
I installed DietPI.
I couldn't setup xserver (screen not found).
Could you tell us what you did in order to bring up the xserver?
Besides that, it's amazing.
It has an EXCELLENT setup menu, and it's really fast!
I think it's faster than the bionic lxde.
(10-22-2018, 02:22 PM)jannerman Wrote: I installed DietPI.
I think I commented out something in the /etc/X11/xorg.conf file, don't remember if it was a line that said "armsoc" or not, but it might be.
Try commenting out the driver line in that file and see if that helps.
You where right.
It was in /etc/X11/xorg.conf.d
I renamed the armsoc config.
No sound and GPU accelaration.
Same issues with PCIe card (system freezes in X11)
Still, is great as a server Smile
Added DietPi (v6.14) on Pine64 Installer
Thanks for posting this, I was able to get xorg to run by doing this, but does this prevent X from utilizing the MALI T-860?
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 23,019 09-27-2026, 11:42 AM
  New OS for RockPro64 is here, TwisterOS Armbian jtremblant 92 183,754 08-17-2024, 02:32 PM
Last Post: taltamir
  OpenEuler OS on RockPro64 Yuriy Gavrilov 0 3,428 06-15-2024, 09:38 AM
Last Post: Yuriy Gavrilov
  yocto for RockPro64 Fide 1 5,265 01-16-2024, 10:01 AM
Last Post: Fide
  Installing Ubuntu Server on RockPro64 deutschlmao 2 10,378 10-29-2023, 04:43 PM
Last Post: brotherj4mes
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 44,977 08-16-2023, 01:34 AM
Last Post: varac
  slarm64 (unofficial slackware) ROCKPro64 RK3399 (aarch64) mara 54 132,029 08-11-2023, 11:13 AM
  How to enable CoreSight ETM trace on RockPro64 shpark 0 4,911 05-21-2023, 11:34 PM
Last Post: shpark
  Rockpro64 Dead on arrival? quixoticgeek 1 4,354 03-12-2023, 06:55 PM
Last Post: quixoticgeek
  RockPro64 boot questions misterc 3 6,940 01-13-2023, 06:21 PM
Last Post: misterc
