Extremely low write speed on GB ethernet
I've had a problem with the write speeds I'm getting over wired connection, I'm only getting about 2-4 MBps at best, when I expect at least 60.
I'v installed auyfan's stretch-openmediavault-rockpro64-0.7.10-1072-armhf, the device is connected to a gigabit router, also tested connecting it directly to my machine with similar results.
I'm suspecting it had something to do with the Realtek RTL8211 driver not installed correctly,
root@rockpro64:~# ethtool -i eth0 driver: st_gmac version: March_2013 firmware-version: expansion-rom-version: bus-info: supports-statistics: yes supports-test: no supports-eeprom-access: no supports-register-dump: yes supports-priv-flags: no
Is there any way to try and install the correct driver for this chip?
Thanks,
Omer.
(10-22-2018, 06:53 AM)omer811 Wrote: Hello,
Thanks,
Omer.
Have you tried disabling rx/tx offloading?
https://github.com/ayufan-rock64/linux-build/issues/263
apparently it was not a problem with the connection, but with the drives that are connected.
when under load, the usb connection the the drives that are connected to the hub crashes.
https://pastebin.com/JGM3xKDz
the hub is a-4 port powered hub by Anker, and two powered sumsung disks are connected to it
hub's lsusb - https://pastebin.com/MiAMh9K5
I'm running 4.4.154-1122-rockchip-ayufan-g7859b9b904a9
with OMV installed
i'v tried the following advice https://bbs.archlinux.org/viewtopic.php?id=183190 on comment #12, which helped a little, the drives became more stable, but disconnected after all.
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 5,014 08-14-2023, 07:55 AM
Last Post: kundanjha
  No USB and Ethernet kreyren 3 6,046 08-18-2022, 10:35 AM
Last Post: kreyren
  RockPro64 ddr clock speed causing system instability CypherShrugged 1 3,853 08-15-2022, 02:32 PM
Last Post: CypherShrugged
  speed and stability tests luckyrockpro 0 2,885 05-29-2019, 08:15 AM
Last Post: luckyrockpro
  OMV Samba speed tweak? g_t_j 0 3,412 05-11-2019, 11:12 AM
Last Post: g_t_j
Sad RockPro64 with OpenMediaVault - Ethernet card is not recognized eduapof 8 20,031 04-18-2019, 08:28 AM
Last Post: g_t_j
  SD Card UHS speed hopkinskong 5 11,277 12-06-2018, 05:52 PM
Last Post: z4v4l
  Not able to write u-boot to SPI Jix0 2 8,144 11-13-2018, 09:39 AM
Last Post: Bullet64
  u-boot serial port speed? zener 2 6,978 10-06-2018, 12:47 PM
Last Post: zener
  rock64pro - using gigabit ethernet dongle on usb type C dkebler 2 9,940 09-07-2018, 12:41 AM
Last Post: steamiestoyster
