Is my board dead? [SOLVED]
Both Ethernet lights are solid. Power light comes on.
White light doesn't.
No power to USB drive.
Nothing on HDMI output.
Only used it a handful of times...
I'm using debian minimal and the white led only kicks in when the image starts booting.
Has it worked in the past? if so what happened before it stopped working?
I believe I'm a moron. lmao.
I thought I double, triple checked, but I downloaded....
bionic-minimal-rock64-0.7.9-1067-arm64
bionic-minimal-rock64-0.7.10-1072-arm64
I need:
bionic-minimal-rockpro64-0.7.10-1072-arm64
::facepalm::
+1 vote for a more obvious naming scheme.... perhaps a PREFIX of rock64/rockpro64 to separate the builds listed alphabetically...
>>Created an issue if anyone has anyone has any input: https://github.com/ayufan-rock64/linux-build/issues/289
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 6,225 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 4,904 08-14-2023, 07:55 AM
Last Post: kundanjha
  Cannot get my board to boot deutschlmao 11 20,092 09-05-2022, 04:23 PM
Last Post: ljones
  Is my rockpro dead? k0sm 6 10,927 12-30-2021, 07:32 PM
Last Post: Rocklobster
  Never ever mix up CPU board connector with 8-pin PCIE connector LMM 0 3,420 02-11-2021, 10:18 AM
Last Post: LMM
  RockPro64 SSD Expansion Board/SATA Shield as0zial 5 12,974 10-18-2020, 08:05 PM
Last Post: revoman
  board not working kardanadm 7 15,315 08-31-2019, 07:37 AM
Last Post: kardanadm
  board not working with EMMC RockPro64Newbie 1 4,808 05-10-2019, 02:22 AM
Last Post: Unkn0wn
  Is my board dead? (again) duckkcud 8 13,285 01-24-2019, 07:12 PM
Last Post: 40four
  measurements in mm of the ROCKPRO64 SBC board? killor 2 8,518 03-10-2018, 08:44 AM
Last Post: killor
