Copper cooler for Rockpro64
Found this copper cooler on ebay. Fits nicely except the area around the WIFI/Bluetooth card attaches so had to bend the fins a little bit. But all in all a nice passive cooler. it does have a fan that comes with it but would need connection modification. Just wanted to share this.
Pretty cool. Looks like an old GPU heatsink.
Question
Is eMMC from ODROID supported?
I believe so, that's where I got my RockPro64. I like the board but the OS is still young.
Got myself a larger heatsink which works well. Stock Pine64 30mm job weighs 62g, this thing weighs 110g so should be useful. Running cpuminer as a benchmark indicates it is: stock 30mm at 2GHz was reaching 80C after about 15 minutes and throttling, this new sink seems to be able to keep under 80C (ambient 23C) indefinitely and running RockPro at 2.1/1.5GHz.
Had to mount it on the long axis of the board to prevent interference with the PCIe card. Available all over Fleabay - I happened to get mine from this vendor with no problems.
(09-29-2018, 09:01 AM)dukla2000 Wrote: Got myself a larger heatsink which works well. Stock Pine64 30mm job weighs 62g, this thing weighs 110g so should be useful. Running cpuminer as a benchmark indicates it is: stock 30mm at 2GHz was reaching 80C after about 15 minutes and throttling, this new sink seems to be able to keep under 80C (ambient 23C) indefinitely and running RockPro at 2.1/1.5GHz.
Damn, thats nice...
Very nice. Wonder if it's to big to work with the NAS case?
(09-29-2018, 01:40 PM)Takenover83 Wrote: Very nice. Wonder if it's to big to work with the NAS case?
With 3.5" drives there has got to be no chance. With 2.5" dunno - the tips of the heatpipes are about 115mm above the PCB.
My guess should be OK with 2.5"" due to the installation may not block the heatsink placement.
What base is the board secured to? I'm assuming it's a tiered / stack-able platform?
  TPM module for rockpro64 misha64 0 2,771 12-03-2024, 06:19 PM
Last Post: misha64
  ROCKPro64 Battery Power Supply hoarfrosty 12 9,919 04-01-2024, 10:24 PM
Last Post: nano2
  Powering on the Rockpro64 JPT223 1 3,173 09-24-2023, 12:23 PM
Last Post: hoarfrosty
  ROCKPro64 with 16 ports SATA controller ZeblodS 19 39,895 12-18-2022, 06:25 PM
Last Post: heyghoge
  Using RPI hat on RockPro64? misterc 0 2,986 12-16-2022, 02:05 PM
Last Post: misterc
  GPIO on the RockPro64 - all pins high? colinmarc 2 4,903 11-18-2022, 10:20 AM
Last Post: colinmarc
  ROCKPro64 DOA ajtravis 8 13,411 11-08-2022, 03:40 AM
Last Post: ajtravis
  RockPro64 not booting up mvicha@gmail.com 0 3,508 09-19-2022, 07:35 AM
Last Post: mvicha@gmail.com
  GPIO Expander HAT for ROCKPro64 and Quartz64 CounterPillow 7 11,835 07-18-2022, 10:05 PM
Last Post: zer0sig
  RockPro64 premium aluminium casing justwantin 2 5,292 05-27-2022, 06:51 PM
Last Post: justwantin
