09-21-2018, 03:57 AM
Copper cooler for Rockpro64
09-21-2018, 04:44 AM
Pretty cool. Looks like an old GPU heatsink.
Is eMMC from ODROID supported?
my SOHO NAS RockPro64 4GB v2.1 / eMMC 32GB / PCIe -> 4*SATA Marvell 88SE9235 / SD-card 64 GB / NAS Casing / image Debian Stretch Minimal / Kernel 4.4.xxx ayufan my Multimedia desktops: ASUS H310T G5500, ODROIDs -XU4, -XU3, -C2, -C1; my trash BananaPi; RPi B, B+; ODROID-W
09-22-2018, 05:22 AM
I believe so, that's where I got my RockPro64. I like the board but the OS is still young.
09-29-2018, 09:01 AM
(This post was last modified: 09-29-2018, 09:03 AM by dukla2000.
Edit Reason: typo
Got myself a larger heatsink which works well. Stock Pine64 30mm job weighs 62g, this thing weighs 110g so should be useful. Running cpuminer as a benchmark indicates it is: stock 30mm at 2GHz was reaching 80C after about 15 minutes and throttling, this new sink seems to be able to keep under 80C (ambient 23C) indefinitely and running RockPro at 2.1/1.5GHz.
Had to mount it on the long axis of the board to prevent interference with the PCIe card. Available all over Fleabay - I happened to get mine from this vendor with no problems.
09-29-2018, 09:08 AM
(09-29-2018, 09:01 AM)dukla2000 Wrote: Got myself a larger heatsink which works well. Stock Pine64 30mm job weighs 62g, this thing weighs 110g so should be useful. Running cpuminer as a benchmark indicates it is: stock 30mm at 2GHz was reaching 80C after about 15 minutes and throttling, this new sink seems to be able to keep under 80C (ambient 23C) indefinitely and running RockPro at 2.1/1.5GHz. Damn, thats nice...
09-29-2018, 01:40 PM
(09-29-2018, 09:01 AM)dukla2000 Wrote: Got myself a larger heatsink which works well. Stock Pine64 30mm job weighs 62g, this thing weighs 110g so should be useful. Running cpuminer as a benchmark indicates it is: stock 30mm at 2GHz was reaching 80C after about 15 minutes and throttling, this new sink seems to be able to keep under 80C (ambient 23C) indefinitely and running RockPro at 2.1/1.5GHz. Very nice. Wonder if it's to big to work with the NAS case?
09-29-2018, 02:34 PM
(09-29-2018, 01:40 PM)Takenover83 Wrote: Very nice. Wonder if it's to big to work with the NAS case? With 3.5" drives there has got to be no chance. With 2.5" dunno - the tips of the heatpipes are about 115mm above the PCB.
10-04-2018, 03:42 PM
(09-29-2018, 02:34 PM)dukla2000 Wrote:(09-29-2018, 01:40 PM)Takenover83 Wrote: Very nice. Wonder if it's to big to work with the NAS case? My guess should be OK with 2.5"" due to the installation may not block the heatsink placement.
10-30-2018, 08:35 AM
(09-29-2018, 09:01 AM)dukla2000 Wrote: Got myself a larger heatsink which works well. Stock Pine64 30mm job weighs 62g, this thing weighs 110g so should be useful. Running cpuminer as a benchmark indicates it is: stock 30mm at 2GHz was reaching 80C after about 15 minutes and throttling, this new sink seems to be able to keep under 80C (ambient 23C) indefinitely and running RockPro at 2.1/1.5GHz. What base is the board secured to? I'm assuming it's a tiered / stack-able platform? |
| Powering two disks from RockPro64 | some_pinephone_user | 3 | 6,731 |
02-24-2026, 04:43 PM Last Post: evilbunny |
| TPM module for rockpro64 | misha64 | 0 | 3,960 |
12-03-2024, 06:19 PM Last Post: misha64 |
| ROCKPro64 Battery Power Supply | hoarfrosty | 12 | 15,197 |
04-01-2024, 10:24 PM Last Post: nano2 |
| Powering on the Rockpro64 | JPT223 | 1 | 4,672 |
09-24-2023, 12:23 PM Last Post: hoarfrosty |
| ROCKPro64 with 16 ports SATA controller | ZeblodS | 19 | 50,550 |
12-18-2022, 06:25 PM Last Post: heyghoge |
| Using RPI hat on RockPro64? | misterc | 0 | 4,126 |
12-16-2022, 02:05 PM Last Post: misterc |
| GPIO on the RockPro64 - all pins high? | colinmarc | 2 | 6,869 |
11-18-2022, 10:20 AM Last Post: colinmarc |
| ROCKPro64 DOA | ajtravis | 8 | 17,528 |
11-08-2022, 03:40 AM Last Post: ajtravis |
| RockPro64 not booting up | mvicha@gmail.com | 0 | 4,778 |
09-19-2022, 07:35 AM Last Post: mvicha@gmail.com |
| GPIO Expander HAT for ROCKPro64 and Quartz64 | CounterPillow | 7 | 15,637 |
07-18-2022, 10:05 PM Last Post: zer0sig |
