Second Order Not Showing Up
I've ordered the $59 package and I'm pretty sure that I ordered the case that will fit the LCD and the LCD when I did the survey.  For some reasons I cannot track that.  All I see under my pledge is the following
$59
The PINE A64+ IoT Package
You will get the PINE A64 1GB unit along with 8GB MicroSD Pre-Loaded with openHAB software, 802.11N Wifi + Bluetooth 4.0 Module, Z-Wave Plus IO Card, PINE64 Power Supply, and the PINE64 Enclosure. You can upgrade to a 2GB model later for $10.
(Light Assembly Required)
Ships anywhere in the world
Estimated delivery: Apr 2016
Where can I actually look and see if that purchase went through? I don't think it has went through my credit card either.   If that's the case where is the link to order extra stuff?
(03-24-2016, 05:54 PM)AUDIOTEK Wrote: I've ordered the $59 package and I'm pretty sure that I ordered the case that will fit the LCD and the LCD when I did the survey.  For some reasons I cannot track that.  All I see under my pledge is the following
$59
please email to support@pine64.com. however, they are overwhelm on email rely and will be slow.
... TL
$59
... TL
OK Thanks I just did.  But where is the link to buy all the extra accessories?
$59
... TL
The KS team will start the online store link at www.pine64.com around mid April.
OK thanks So the only way I would of put that order in is with the survey? It's been a little while now so I really can't remember how everything got done at my end!!!
  Undelivered Order #375842 – Address Issue serhii.karpov.2025 0 3,031 06-12-2025, 11:21 AM
Last Post: serhii.karpov.2025
Star Why I can't order to Ukraine? undefinedCat 2 8,528 09-29-2022, 08:52 AM
Last Post: deniszpua
  No response from Order Support IbrokeTTL 2 8,154 02-20-2022, 12:37 AM
Last Post: lot378
Question Order not possible to Austria harry75 4 12,554 02-07-2022, 02:16 PM
Last Post: davidroy39
  Placed an order for a Pinebook Pro yesterday mangofett 8 18,897 06-30-2020, 07:38 AM
Last Post: dieselnutjob
  No Order Confirmation or Invoice Number? littleangel77007 1 7,046 12-22-2019, 01:46 PM
  Where is my order? greenhobby 5 13,869 02-18-2019, 12:11 PM
Last Post: greenhobby
  No order confirmation, no tracking number, NOTHING after an order Osiander 1 6,793 11-13-2018, 11:17 AM
  I'll like to place an order...from CHINA uncle_bear 8 18,031 07-26-2018, 01:28 AM
Last Post: Ryan
Exclamation Did My Order Get Lost? JeffD 3 9,168 07-14-2018, 07:37 AM
Last Post: JeffD
