usb 3 gigabit ethernet adapter
Can anyone recommend a usb 3 gigabit ethernet adapter that they know works with the Rock64?
I'm looking to build a firewall and thought of the Rock64.
Thanks in advance....
(09-24-2018, 05:58 AM)frewind Wrote: Hi,
The rock64 has a second ethernet port, you just need this:
https://www.pine64.org/?product=rock64-s...d-on-board
Thanks, but link states 'with 10/100 Mbps Ethernet Port' not 1000 Mbps
Information Rock64 RTL8188EU Wifi Adapter from Pine Store Tested Well MarkHaysHarris777 7 17,713 05-13-2020, 06:00 PM
Last Post: Leon Rembowski
Question Have eMMC adapter - but can't seem to fix eMMC card SirRyanTheGeek 3 11,822 05-04-2019, 04:19 AM
Last Post: burito111
  Will Gert's VGA666 adapter work with the Rock64? Other display options? pcosm 0 3,286 05-03-2019, 01:32 AM
Last Post: pcosm
  Does the Pine usb to sata adapter work with hd-parm? FabrizioMaurizio 0 3,277 02-06-2019, 11:37 AM
Last Post: FabrizioMaurizio
  ROCK64 STEREO AUDIO DAC ADD-ON BOARD and USB serial adapter for Pine64 jovval 2 6,653 12-01-2018, 03:53 AM
Last Post: jovval
  50 kb with RTL8188eu WIFI adapter Juice4 2 6,479 11-09-2018, 12:56 PM
Last Post: Juice4
  Flashing full image to eMMc with a mSD card to eCMM adapter pytheas 2 6,536 04-09-2018, 03:56 AM
Last Post: Luke
  ATTN: Pine 64 Marketing Department - Fix your PoE Adapter Product Page dotbowder 4 12,626 03-02-2018, 06:00 AM
Last Post: mjsmall
Question How can I use the internal 100M ethernet? gabrielmartinslima 1 4,568 02-12-2018, 02:10 PM
Last Post: dkryder
  Yet another thread on ROCK64 Wifi Adapter Woes zendrummer74 1 5,910 02-01-2018, 11:10 PM
Last Post: a1w.ca
