enable ssh at first boot
I have downloaded Debian Stretch Minimal and and burned on eMMC.
The Rock64 is booting, but I do not have any clue how to enable the ssh on boot, its headless.
Can somebody help me?
ssh is enabled by default.
(09-11-2018, 08:52 AM)Luke Wrote: ssh is enabled by default.
when try to connect to the server I get constantly
BigiMac:$ ssh rock64@192.168.3.106
Connection closed by 192.168.3.106 port 22
You'll probably need to enter you login credentials to open an SSH session
Does not prompt for credentials
Maybe you could try dropping a blank text file called SSH. into the /boot folder of the eMMC similar to the method of enabling SSH in the Raspberry Pi
If SSH is supposed to be enabled by default it's definitely down to a credentials issue. Try PuTTY for Windows or Linux to see if that works. If all else fails try Termius for the iPad or iPhone.
(09-11-2018, 07:19 AM)lukics Wrote: I have downloaded Debian Stretch Minimal and and burned on eMMC.
Are you sure it is booting correctly? how? are you sure thats the correct IP? IMO even if its meant to be used headless its super easy to just plug it to some tv for a few minutes to setup the bare minimals then move it to their intended place...
If i remember correctly SSH should be on by default (and luke say the same) but i didnt set up a new install since a few months now...
  A/V output enable 8lall0 0 846 03-24-2026, 04:45 PM
Last Post: 8lall0
  PXE Boot example? lewis 7 16,936 10-08-2025, 06:51 AM
Last Post: LewisHenderson
  How to boot an older, working kernel bits 0 2,573 11-01-2024, 04:43 PM
Last Post: bits
  problem with debian emmc boot G4zCDzWb 10 12,650 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 4,426 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  Rock64 won't boot dstallmo 0 3,141 12-27-2023, 10:34 AM
Last Post: dstallmo
  Disabling last mount time check on boot acwest 0 2,144 03-03-2023, 09:24 PM
Last Post: acwest
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 13,211 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 2,676 06-27-2022, 06:52 PM
  Setting a MAC on Rock64 U-Boot kiriakos 2 6,404 03-23-2021, 04:51 AM
Last Post: kiriakos
