Schematics of Wifi/BT module
Is there available the schematics of Wifi/BT module?
Thank you
There is no schematic of the module, just the pinout on the regular Pine64 schematics, it is just a carrier board for the Realtek module... what info do you need?
I just want to implement into my board with SOPINE the RTD8723BS chip, and I want to make it working with default driver in SOPINE linux images (dunno if it's using modified version or it's used the module which is in the kernel). Also, it would be possible to use AP6359SA in SOPINE (i think this shouldn't be a problem), and also provide schematics from the board? RTD8723BS is very unstable on Linux and I would be glad to use something more stable and reliable :-)
(09-06-2018, 02:11 AM)gamelaster Wrote: I just want to implement into my board with SOPINE the RTD8723BS chip, and I want to make it working with default driver in SOPINE linux images (dunno if it's using modified version or it's used the module which is in the kernel). Also, it would be possible to use AP6359SA in SOPINE (i think this shouldn't be a problem), and also provide schematics from the board? RTD8723BS is very unstable on Linux and I would be glad to use something more stable and reliable :-)
For hardware point of view, possible to use AP6359A but somebody needs to develop the driver.
BRCMFMAC driver contains a support for AP6358SA, there is a driver for it which have config for AP6358SA:
https://github.com/kszaq/brcmfmac_sdio-firmware-aml
I could try to implement for SOPINE, just I need schematics of module for Rock64Pro, since there is almost no documentation for this chip so I can't make my own board. It will be possible to publish it?
Should able to publish Lets me request and may takes few days for the release.
Here is the ROCKpro64 Wifi/BT schematic, http://files.pine64.org/doc/rockpro64/ro...6359SA.pdf
Note that this module can plug into the PINE A64 board but no driver available yet.
Thank you tllim, I highly appreciate that. I will try to make it working on SOPINE, I will tell the results later
  [split] Better WiFi/BT module? moriel5 3 10,465 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 8,727 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 43,026 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 7,210 07-30-2020, 04:53 PM
Last Post: S265
  Create a WiFi hotspot on Debian 8 JulianM 6 33,758 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Wireless Module Driver Source code mido2018 0 3,546 08-08-2018, 04:26 PM
Last Post: mido2018
  Installing another WiFi module on one of the buses mido2018 1 6,147 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 24,712 02-21-2018, 09:56 PM
Last Post: dkebler
  Pine64 doesn't recognize Wifi/BT Module clobeca 3 10,062 07-13-2017, 08:58 PM
Last Post: MarkHaysHarris777
Sad wifi direct bj_jung 2 8,478 12-29-2016, 10:26 AM
Last Post: happytuna
