PCI-E X4 to M.2/NGFF NVMe SSD - support?
I have the PCI-E X4 to M.2/NGFF NVMe SSD card and wondered what type of M.2 drives people may be using?  Also wondering if this card and M.2 drives (like the Samsung 970 PRO 512GB - NVMe PCIe M.2 2280 SSD) are supported under (ayufan) Ubuntu Bionic?  Thanks for any info...
(08-03-2018, 12:38 PM)AndyOfLinux Wrote: I have the PCI-E X4 to M.2/NGFF NVMe SSD card and wondered what type of M.2 drives people may be using?  Also wondering if this card and M.2 drives (like the Samsung 970 PRO 512GB - NVMe PCIe M.2 2280 SSD) are supported under (ayufan) Ubuntu Bionic?  Thanks for any info...
I use bionic-minimal-rockpro64-0.7.9-1067-arm64.img.xz and tested
  • Samsung 960 EVO m.2 250 GB
  • Samsung 970 PRO m.2 512 GB
Both without any problem.
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
I've hit a wall with attempting to get lscpi giving any output & the PCI-E slot working. Anyone know of a fix for this?
Which version of the board do you have?
3. RockPro64 v2.1
Revision 2.1
Forget to ask.
Which Image do you use?
Which pcie card do you use?
Both cards from pine64 works fine with bionic-minimal-rockpro64-0.7.9-1067-arm64.img.xz and v2.1
3. RockPro64 v2.1
bionic-lxde-rockpro64-0.7.9-1067-arm64
PINE64 DW-PCIe-M2-2(Ver.A)
I've used both the newest linux-kernel & linux-mainline-kernel from ayufan
dmesg dump
https://www.dropbox.com/s/2z8h634wgv3dwe...g.txt?dl=0
Please test with bionic-minimal.
And for dumps https://pastebin.com
3. RockPro64 v2.1
Thanks for the responses with great info!  I installed a Samsung 970 EVO 500GB - NVMe PCIe M.2 2280 SSD, using board v2.1 with bionic-lxde-rockpro64-0.7.9-1067-arm64.  Works great   Big Grin  but hopefully we'll get more performance in the future with newer firmware &/or OS releases?
With my ROCKPro64 and Samsung 970 EVO:
sudo hdparm -tT --direct /dev/nvme0n1
/dev/nvme0n1:
 Timing O_DIRECT cached reads:   1110 MB in  2.00 seconds = 555.17 MB/sec
 Timing O_DIRECT disk reads: 1668 MB in  3.00 seconds = 555.50 MB/sec
With my Intel i5 NUC  and Samsung 950 PRO:
/dev/nvme0n1:
 Timing O_DIRECT cached reads:   1978 MB in  2.00 seconds = 989.90 MB/sec
 Timing O_DIRECT disk reads: 3210 MB in  3.00 seconds = 1069.41 MB/sec
Are you using mainline kernel? Atm, mainline kernel is faster.
3. RockPro64 v2.1
  ADATA XPG SX8200 Pro 2TB NVMe SSD Perf Atch 0 2,993 04-01-2023, 02:51 PM
Last Post: Atch
  PCIe bifurcation support (on RK3399) Arn 1 4,427 11-28-2022, 05:12 PM
  Support for Refresh rates Above 60 publiclewdness 0 2,349 01-01-2022, 11:40 PM
Last Post: publiclewdness
  Full Size Bracket for the NVME PCI-E Card publiclewdness 0 2,768 12-31-2021, 12:53 AM
  zfs on rockpro64 - any dual nvme PCI adapter for software raid ? romadr 0 3,090 04-22-2021, 02:59 PM
Last Post: romadr
  case for RockPro64 + PCI-E M.2 NVMe Card? AndyOfLinux 9 20,135 01-05-2021, 05:05 PM
Last Post: kuleszdl
  PCI Express x4 Device Support machinevault 4 11,192 07-13-2020, 01:32 PM
Last Post: pgwipeout
  12V 3A power supply and NVMe - PCIe kaylios 3 8,489 08-25-2019, 03:31 AM
Last Post: kaylios
  Need to add various Wifi chipset support slappymcphee 6 12,563 08-15-2019, 05:26 PM
Last Post: evilbunny
  JMicron cipset SATA PCI-E card support Yroth 2 6,155 07-27-2019, 08:52 PM
Last Post: stuartiannaylor
