Do I need a touchscreen to run Android?
Question
I would like to install Android 8.1 on my Rock64 4G.
http://wiki.pine64.org/index.php/ROCK64_...ndroid_8.x
Will I be able to run Android without touchscreen... with keyboard and mouse (USB connected)?
It should work, USB mouse and Keyboard work on my phone without a problem so if they did not remove the drivers for those it should just work.
(08-04-2018, 09:04 PM)chrbar Wrote: Hi,
Yes, a keyboard and mouse is all you need.
Ok thanks Paradis and Luke, it's worked correctly with keyboard and mouse.
I meet a problem with the Play Store App: when I run it I obtain the message "this version of the app isn't compatible with your device. to fix this problem, go settings and uninstall updates for the Google Play Store app".
Does this message is common about Google Play Store app, with Android on Rock64?
I've checked settings but there is no installed update to delete!
I've cleaned cache and others things found, but the message still appears!
Install and run Android 8.1 was my first experience with the Rock64!
I've installed Android 7.1.2 to see if I meet the same problem.
I'm able to start Play Store app without error message, but I'm not able to sign in: nothing when I clik on "Sign in" button!
Do you have some advice to help me to run Play Store app on my Rock64, and be able to install new Apps on it?
Chris
  ethernet lan speed problem android fulltone 0 4,035 04-23-2018, 01:47 AM
Last Post: fulltone
  No sound on Android 6 or 7.1 reeno 0 4,310 07-29-2017, 06:31 PM
Last Post: reeno
  Android pretty slow Passiday 2 7,954 10-08-2016, 03:46 AM
Last Post: Passiday
  Can't make the Android image boot Passiday 3 8,925 10-07-2016, 09:34 AM
Last Post: Passiday
  LCD screen with android, runs fine, screen does not turn back on..? GhostlyAspens 2 6,805 09-01-2016, 12:24 AM
Last Post: GhostlyAspens
  No IMG file after extracting Android dd tomwjr 15 34,592 08-12-2016, 03:53 PM
Last Post: tomwjr
  Can't get past the "Allwinner/Android" screen d34532 2 7,605 07-10-2016, 08:21 PM
Last Post: d34532
Exclamation Arrived today...cannot boot to touchscreen or HDMI? editfish 6 15,916 07-02-2016, 10:04 AM
Last Post: 84thProblem
Thumbs Down Issues with Android mliebski 0 3,281 07-01-2016, 11:14 AM
Last Post: mliebski
  Audio / Touchscreen - 2 New Stupid Questions phloog 1 5,875 06-26-2016, 07:17 PM
