PCIe -> SATA and NVMe work as of 0.6.59
(07-25-2018, 12:47 PM)dukla2000 Wrote:
(07-25-2018, 05:17 AM)Bullet64 Wrote: Look -> https://gist.github.com/ayufan/30c46381c...4a752946db
He is using an Samsung PM961
I did see on his lspci output it was reported as
"Subsystem: Samsung Electronics Co Ltd NVMe SSD Controller SM961/PM961", but pfeerick 960 EVO output is identical.
My limited insight to Samsung 960 NVMe devices indicates SM961 and PM961 devices were released to OEMs early in 2016. And Samsung later released EVO and PRO versions for the general public. However, as per Anandtech there are differences in the NAND chips which is what I expect explains the difference in iozone numbers from ayufan and pfeerick?
If the table at Anandtech is accurate then actual PM961 devices should be the slowest of the lot.
I remember, that Ayufan postet that he has an 960 Pro. But that is only from my memory, I can be wrong too. Waiting for Ayufan...
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
I do have 960Pro but in my PC. For RockPro64 I use separate NVMe drive with SM961 (This is on sticker).
Homepage: https://ayufan.eu
Releases:
Buy me a Beer
Is it possible to switch system root "\" to PCIe NVMe SSD?
or
Boot directly from PCIe NVMe SSD?
Hopefully someone can figure it out how to do it.
thanks
I managed to get a used 128GB SM961 for a bargain price: came with some no-name PCIe adapter and worked first time:
/ssd$ sudo iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
    Iozone: Performance Test of File I/O
            Version $Revision: 3.429 $
        Compiled for 64 bit mode.
        Build: linux
    Contributors:William Norcott, Don Capps, Isom Crawford, Kirby Collins
                 Al Slater, Scott Rhine, Mike Wisner, Ken Goss
                 Steve Landherr, Brad Smith, Mark Kelly, Dr. Alain CYR,
                 Randy Dunlap, Mark Montague, Dan Million, Gavin Brebner,
                 Jean-Marc Zucconi, Jeff Blomberg, Benny Halevy, Dave Boone,
                 Erik Habbinga, Kris Strecker, Walter Wong, Joshua Root,
                 Fabrice Bacchella, Zhenghua Xue, Qin Li, Darren Sawyer,
                 Vangel Bojaxhi, Ben England, Vikentsi Lapa.
    Run began: Mon Aug  6 18:16:56 2018
    Include fsync in write timing
    O_DIRECT feature enabled
    Auto Mode
    File size set to 102400 kB
    Record Size 4 kB
    Record Size 16 kB
    Record Size 512 kB
    Record Size 1024 kB
    Record Size 16384 kB
    Command line used: iozone -e -I -a -s 100M -r 4k -r 16k -r 512k -r 1024k -r 16384k -i 0 -i 1 -i 2
    Output is in kBytes/sec
    Time Resolution = 0.000001 seconds.
    Processor cache size set to 1024 kBytes.
    Processor cache line size set to 32 bytes.
    File stride size set to 17 * record size.
                                                              random    random     bkwd    record    stride
              kB  reclen    write  rewrite    read    reread    read     write     read   rewrite      read   fwrite frewrite    fread  freread
          102400       4    97119   119275   141604   141757    46120    81382
          102400      16   264668   349135   374752   381088   116056   253526
          102400     512   747897   764013   740837   850397   748669   759626
          102400    1024   646955   760683   795914  1002654   895096   761269
          102400   16384   700665   741865  1002589  1239458  1229366   747861
iozone test complete
Now to sort SPI (or wait for Ayufan Smile  )
  RK3399 PCIe enumeration jhadd 0 3,275 01-31-2024, 08:56 AM
Last Post: jhadd
Question nand-sata-install on RAID-1 array ARMandHammer 1 3,604 02-12-2023, 03:10 AM
Last Post: igorp
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 6,950 10-14-2022, 06:24 AM
Last Post: rwk-
  Need help! Can't get device mode to work. scanboy 6 12,017 12-29-2021, 08:35 PM
Last Post: djonathan
  No PCIe controller detected... Limhes 1 3,712 11-23-2021, 06:23 AM
Last Post: Limhes
  Using the PCIe slot of ROCKPro64 as EndPoint mode nonoriri 1 3,934 11-20-2021, 10:53 AM
Last Post: fire219
  WiFi not working with PCIe SSD installed mikeD 0 2,895 05-25-2021, 07:48 AM
Last Post: mikeD
  Power supply underpowered for Rockpro64, deficient PCIe SATA card, or something else? daffy 8 13,413 05-20-2021, 10:04 PM
Last Post: t4_4t
  Booting from NVME ilovegentoo 11 21,366 05-10-2021, 02:06 PM
Last Post: rrowles2000
  Upgrade Debian kernel on a SD/SATA drive boot combo. linuxha 6 14,050 12-12-2019, 04:43 AM
Last Post: dukla2000
