[Archived] ANNOUNCING RECALBOX FOR THE ROCK64 - ALPHA RELEASE
#81
@Luke i think with
Quote:u-boot for the rock64 is still being developed? is there plans to support this use case in the future?
He wants to know, if you will Support Booting from USB (and not just SD card)
#82
(07-20-2018, 06:55 AM)gigagames Wrote: @Luke i think with
In fact i was refering to the dual boot i was asking before but he already answered that part...
#83
Eventually got round to trying it on my Rock64, all I can say is awesome work for an alpha. most things seem to work pretty flawlessly, the problems I did note were mainly down to the controllers, would only recognise a wired Xbox 630 controller, none of my cheap USB SNES controllers, homemade USB arcade controller or Bluetooth 8bitdo would work. The wired controllers were being picked up by the system (ssh's into the box and had a bole about) but info not reaching emulationstation. Limited keyboard and settings available. But hey, it's alpha, I hope these will be sorted soon. Most MAME worked well, Playstation was flawless, N64, well, graphic glitches.
One thing that utterly blew me away was transferring roms, Gigabit ethernet v old Raspberry pi makes all the difference in setting up.
Keep up the excellent work.
#84
Hello Luke,
First, great work !
I've tried the Alpha version in GitHub.
I'm using a monitor DVI. So I have a cable adaptor HDMI > DVI.
For the sound I would like to use the A/V jack.
In the audio settign I've only HDMI. I've tried to force "jack" manually the recalbox conf file. It doesn't work.
To be sure it was not a hardware issue, I've tried with other linux distri, and lakka, it works fine.
(I did not try with a HDMI monitor).
Any idea about this ? (On the video you've put tho show your work on Recalbox/Rock64 there was no sound as well).
Best regards !!
#85
stealthbanana,
Yes, the alpha has a limited controller compatibility. Beta will be much better in this respect.
pascal06n,
Indeed, the jack doesn't work on the alpha image and there is no easy way to get it working. Obviously it will work nicely on our upcoming beta - just hang tight. The alpha is there really just for testing and as a proof of concept.
Thanks Smile
#86
Awesome to see!
#87
I'm not seeing anything in the github with the exception of a text file. Is this still being actively worked on?
#88
(07-25-2018, 01:25 PM)KryPtAlIvIaN Wrote: I'm not seeing anything in the github with the exception of a text file. Is this still being actively worked on?
This link ? https://github.com/mrfixit2001/recalbox_rock64/releases
Of course it being worked on Smile Beta incoming soon - 3 months of hard work, sweat and tears....
#89
I can't wait anymore... Cry
#90
(07-25-2018, 02:19 PM)Danielsan Wrote: I can't wait anymore... Cry
Just to explain what is happening. We've got a completed build, but the issue is that it doesn't boot on some boards (kernel panic) while it boots on others. This is really what we've been troubleshooting and debugging for quite some time - nearly a month. But we're there now in terms of stability. Just some finishing touches. Thank you for your patience Wink
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 21,834 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,328 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 98,816 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,194 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,752 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,760 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,086 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,284 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,152 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 119,161 09-01-2024, 06:05 AM
Last Post: RaymondDay
