slarm64 (unofficial slackware) Rock64 RK3328 (aarch64)
#31
yes, it was necessary to specify that the "sdcard" is a "micro sd card".
thank you.
it's nice to hear that the system is working on your board.
Added Slackware Aarch64 Miniroot (ROCK64) 20180508 on Wiki and PINE64 Installer.
Added Slackware Aarch64 XFCE (ROCK64) 20180508 on Wiki and PINE64 Installer.
(05-21-2018, 01:43 AM)pineadmin Wrote: Added Slackware Aarch64 Miniroot (ROCK64) 20180508 on Wiki and PINE64 Installer.
many thanks,
the only thing, since this port (aarch64) is not an official trademark of Slackware is not correctly used. The project for rebuilding Slackware under the aarch64 architecture was re-named in Slarm64, but this does not apply to assemblies on the architecture arm
update kernel and packages
the video is played through mpv, 1080p cpu load is 89%
slack-current-aarch64-miniroot_22May18-4.4.132-rock64-build-20180526.img.tar.xz
slack-current-aarch64-miniroot_22May18-4.4.132-rock64-build-20180526.img.tar.xz.md5
slack-current-aarch64-xfce_22May18-4.4.132-rock64-build-20180526.img.tar.xz
slack-current-aarch64-xfce_22May18-4.4.132-rock64-build-20180526.img.tar.xz.md5
graphics are displayed using mali blob gbm
slack-current-aarch64-miniroot_22May18-4.4.133-rock64-build-20180701.img.tar.xz
slack-current-aarch64-miniroot_22May18-4.4.133-rock64-build-20180701.img.tar.xz.md5
slack-current-aarch64-xfce_22May18-4.4.133-rock64-build-20180701.img.tar.xz
slack-current-aarch64-xfce_22May18-4.4.133-rock64-build-20180701.img.tar.xz.md5
R64 4GB wont boot with any Slackware image. Here is a loglevel=8 boot message capture: http://termbin.com/9stym
I tried to blacklist sdio/bcmdhd with a kernel parameter but either my syntax is wrong or the parameters are ignored because they do not appear in the boot log and the error remains. This is what i tried to add to uEnv.txt:
extraargs=rd.blacklist=bcmdhd module_blacklist=bcmdhd
and also
extraargs=rd.blacklist=sdio module_blacklist=sdio
(07-01-2018, 11:06 PM)ansic Wrote: R64 4GB wont boot with any Slackware image.  Here is a loglevel=8 boot message capture: http://termbin.com/9stym
and also
the rtl8188eu, bcmdhd modules are configured as part of the kernel.
if you do not like the output at startup, you can set the verbosity parameter to 1
rebuilt the kernel with support for usb realtek and mediatek in the form of modules
download
http://dl.fail.pp.ua/slackware/pkg/aarch...-3mara.txz
upgradepkg kernel*.txz
dmesg
update kernel 4.4.138
kernel-firmware-rk3328-4.4.138-aarch64-1mara.txz
kernel-headers-rk3328-4.4.138-aarch64-1mara.txz
kernel-modules-rk3328-4.4.138-aarch64-1mara.txz
kernel-rk3328-4.4.138-aarch64-1mara.txz
update kernel 4.4.142
kernel-firmware-rk3328-4.4.142-aarch64-1mara.txz
kernel-headers-rk3328-4.4.142-aarch64-1mara.txz
kernel-modules-rk3328-4.4.142-aarch64-1mara.txz
kernel-rk3328-4.4.142-aarch64-1mara.txz
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 18,696 06-27-2026, 02:43 PM
  rAudio for Rock64 V2/Pine A64+ shinzuka 11 1,856 06-25-2026, 03:16 PM
Last Post: shinzuka
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,129 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,030 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,959 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,232 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,409 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,396 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 86,659 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 110,494 09-01-2024, 06:05 AM
