rock64/ubuntu start-up
#31
(06-15-2018, 12:26 PM)pas059 Wrote: Concerning the wifi, my wifi dongle is detected, but as i did not find a way to use it, i installed the package "network-manager-gnome". After that i have a icon in the taskbar but the icon has a little red cross over it. A clic on it, shows a menu in wich there is an item corresponding to my wifibox. But selecting this item do nothing; if i select the 'Edit connections...' item, a window is open showing my wifi box, but once again trying to edit these connections do nothing. Well,  probably it is necessary to install another packages, but which?
I'm running Ayufan's Bionic-LXDE 0.6.44 and had the same issue with the WiFi and tried installing "network-manager-gnome" but that didn't work. What worked for me was installing Wicd network manager "sudo apt-get install wicd", then I was able to select what wifi network to connect to, etc.
Cheers
I did not have such line
name resolve order = bcast host
in my smb.conf file, so i added it. Unfortunatly this change only the error message from "connection refused" to "invalid argument" Huh . So, i executed the command smbclient and i got this:
smbclient -L 192.168.1.72 WARNING: The "syslog" option is deprecated Enter WORKGROUP\rock64's password: Anonymous login successful Sharename       Type      Comment ---------       ----      ------- smb1cli_req_writev_submit: called for dialect[SMB2_10] server[192.168.1.72] Error returning browse list: NT_STATUS_REVISION_MISMATCH Reconnecting with SMB1 for workgroup listing. Connection to 192.168.1.72 failed (Error NT_STATUS_RESOURCE_NAME_NOT_FOUND) Failed to connect with SMB1 -- no workgroup available
thanks for your help
regards
(06-27-2018, 12:36 PM)pas059 Wrote: Hi,
regards
This is starting to frustrate me as much as it is probably doing to you. I've got one last idea. In smb.conf again, add:
client min protocol = SMB2 client max protocol = SMB3
Save and restart smbd/nmbd.
Hi fire219
with SMBD2/3 as min/max protocol, now smbclient -L 192.168.1.72 gives:
Sharename       Type      Comment ---------       ----      ------- smb1cli_req_writev_submit: called for dialect[SMB2_10] server[192.168.1.72] Error returning browse list: NT_STATUS_REVISION_MISMATCH SMB1 disabled -- no workgroup available
the errors 'NT_STATUS_REVISION_MISMATCH' is always here, i made an apt aupdate/upgrade but this change nothing for smclient. Perhaps something wrong with bionic-LXDE, but what?
regards
Is "WORKGROUP\rock64" a valid user for the network shares? Maybe do the following instead (substituting your username for <WinUsername>)
smbclient -L 192.168.1.72 -U<WinUsername>
there is a difference; $smbclient -L 192.168.1.72 -U winusername gives:
Sharename       Type      Comment ---------       ----      ------- ADMIN$          Disk      Administration �� distance C$              Disk      Partage par d��faut Documents publics Disk       IPC$            IPC       IPC distant Logiciels       Disk       Users           Disk       Reconnecting with SMB1 for workgroup listing. Connection to 192.168.1.72 failed (Error NT_STATUS_RESOURCE_NAME_NOT_FOUND) Failed to connect with SMB1 -- no workgroup available
and if i set min/max protocol to SMB2/3 in smb.conf, this gives:
Sharename       Type      Comment ---------       ----      ------- ADMIN$          Disk      Administration �� distance C$              Disk      Partage par d��faut Documents publics Disk       IPC$            IPC       IPC distant Logiciels       Disk       Users           Disk       SMB1 disabled -- no workgroup available
regards
better news,
i tested the connection to the rock from a pc. To do this i added these lines
[test] comment = For testing only, please path = /export/samba read only = no guest ok = yes
to smb.conf file, and
$mkdir /export/samba/test $chmod 777 /export/samba/test
and this works  Smile . So i suspected a problem on the PC (on windows7), so i tested with another pc (on widows 10), and this works Wink .  Huh . Of course, i have no problem to  connect from one pc to each other. In all cases i use my WinUsername/Password. Perhaps i have to verify some things on the win7 pc Confused
Thanks to all of you for your helps and sorry if i made you lose time.
regards
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 22,005 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 5,472 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 99,368 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 2,236 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,864 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,869 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 4,127 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,340 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 5,192 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 119,646 09-01-2024, 06:05 AM
Last Post: RaymondDay
