Check for aliveness Rock64
I have just received my new ROCK64 2G, I burned the Debian on the SD card and it succeeded. But when I put the SD card into it, nothing happened. The STBY LED, PWR LED, IR LED lighted up but when I plugged it with the TV screen through HDMI, the TV screen didn't show up anything.
Is my ROCK64 dead or are the anything I need to config? Or are there any ways I can check for the life of my ROCK64?
Thank you
(06-22-2018, 10:07 PM)DuyLionTran Wrote: I have just received my new ROCK64 2G, I burned the Debian on the SD card and it succeeded.
What image did you flash to sdcard?
I used the Debian Stretch Minimal Community Build Image,
thank you for your reply
(06-22-2018, 10:37 PM)DuyLionTran Wrote: I used the Debian Stretch Minimal Community Build Image,
Can you please paste the filename? The version in the filename would be helpful because some images are better than others.
(06-22-2018, 10:59 PM)evilbunny Wrote: Can you please paste the filename? The version in the filename would be helpful because some images are better than others.
Or at least a link to the page you downloaded it from, or details of how you access that image. Wink
As well as:
  1. What power supply are you using?
  2. What brand / size of microSD are you using (Samsung EVO is the most compatible/reliable to date)?
  3. What else is connected to the rock64 (other than your TV HDMI)?
Just so we get a better idea of what your setup so other factors can be eliminated.
I got several similar issues with a sd card that had problems or was about to die, in any case i replaced it and even if etcher was reporting no problems with the old card the new card worked like a charm, so, test the card and/or try another...
  Rock64 v2.0 u-boot SPI issues ju0n 0 117 07-05-2026, 11:02 AM
Last Post: ju0n
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 5,531 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 26,491 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 15,713 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 17,318 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,307 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 9,143 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 10,252 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 9,489 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,500 11-28-2022, 02:18 PM
Last Post: Macgyver
