recommended micro sd card ?
#21
(03-18-2016, 06:02 AM)SkairkrohBule Wrote:
(03-18-2016, 05:59 AM)Zoltrix Wrote: Hi, I wonder if it will be ok to use a 8GB or do you recommend 16GB instead?
It will be ok to use an 8GB card, you will just have less space if you wanted to download or store anything (apps, games, movies, etc).
Cards up to 128GB have so far been verified as working.
Ok, I understand. But I have no idé if 8GB will be enough or not today.
#22
8GB is good enough. ... TL
#23
I have try out various brand (Samsung, SanDisk, Sony, Monster, Wintech, Toshiba, Kingston, Patriot, PNY and Transcend ) and capacity (4G - 128G, mostly class 10 and also try out class 6) microSD card, all works well.
So far only encounter issue with this one: Patriot EP series 16GB microSD.
#24
(03-18-2016, 12:39 PM)tllim Wrote: I have try out various brand (Samsung, SanDisk, Sony, Monster, Wintech, Toshiba, Kingston, Patriot, PNY and Transcend ) and capacity (4G - 128G, mostly class 10 and also try out class 6) microSD card, all works well.
Have you done any performance testing to see how the different disks transfer vs their claimed transfer rates? I'm thinking about getting this card for an android tablet built with the playbox enclosure... http://www.amazon.com/SanDisk-microSDXC-...l_huc_item
#25
I have not.
#26
(03-17-2016, 10:04 AM)SkimMilk Wrote: I'm not in the states so won't be able to pick this up. Will be grateful if anyone can help me grab 2 or 3 of these and mail them over to me? Big Grin
http://www.buildapcproxy.com/
Just popped up on reddit
#27
Best Buy has Samsung - EVO+ 64GB microSDHC Class 10 UHS-1 Memory Card - Red/White for $19.99 plus tax with free shipping.
I bought three today.
http://www.bestbuy.com/site/samsung-evo-...1600050002
#28
Samsung Evo cards are a bit scarce in Australia and I was wondering if anyone has tried the Kingston class 10 UHS-I cards? I know it mentioned that the pine64 can't benefit from the UHS speeds but it can still go as fast as non UHS cards am I correct in assuming so? Reason i'm selecting this card is that its pretty cheap here (about 6usd for a 16gb card) and it would be good if performance wise it will be one of the faster ones out there
#29
I am using a Sandisk Ultra 32GB and it works great... $11-15 on Amazon
#30
(04-28-2016, 07:21 AM)hyperlogos Wrote: I am using a Sandisk Ultra 32GB and it works great... $11-15 on Amazon
Me too, works perfect...
Gesendet von meinem K00L mit Tapatalk
Still a linux newbie with several EEE-PCs, PI's, LattePanda and some Desktops/Laptops running Win10. Now also proudly using Pine64+ 2GB and gigabit LAN
  Recommended kits to buy? Silk 1 5,792 12-06-2020, 11:28 PM
  How to boot from SD card on pinebook pro linux123 3 10,374 12-02-2020, 10:29 AM
Last Post: linux123
  micro sd card won't insert Samuel Venable 2 7,124 09-01-2020, 12:15 AM
Last Post: Samuel Venable
  SD Card boot - trying out OS Baconomics 1 7,192 06-19-2020, 06:58 AM
  How to boot from the SD card and install to eMMC? ravanh 2 10,333 03-18-2020, 09:42 AM
  eMMC card on adapter Malmgren 8 18,845 03-20-2018, 11:14 AM
Last Post: Malmgren
  corrupt microsd card after reboot maxpayne 6 16,119 02-08-2017, 05:42 PM
Last Post: maxpayne
  unable to write an pine64 image on a 16G micro suresh 2 8,652 01-26-2017, 12:56 PM
Last Post: suresh
  recommended micro sd card? Gustavo Woltmann 1 6,145 01-03-2017, 11:38 PM
Last Post: MarkHaysHarris777
  What is on the Micro SC card that came with the board? clawinus 1 6,096 11-03-2016, 02:33 PM
