[Archived] ANNOUNCING RECALBOX FOR THE ROCK64 - ALPHA RELEASE
#21
(04-30-2018, 07:05 PM)Mrfixit2001 Wrote: The libraries for nfs could likely be added to the next release, but the users would have to be responsible for the configuration, since nothing in the build actually requires it. So sure, I'll have the config include libnfs for the next image and hopefully that will meet the need! Smile
Initial config could be the same as SMB or none as it does the same thing.
I'll test it when you add it.
Any chance to add/change user for smb? I want to add own user shares that require credentials but it doesn't work for root user.
With core media support I could test it without listening to "daddy where are my movies" all the time.
Don't get me wrong. I really appreciate your work.
I believe users won't want to use Rock64 only for emulation. With proper media support, it's good solution.
This way I can resign from WiFi hotspot or webserver.
I also consider dual boot but I need to buy mSD card.
Wysłane z mojego Redmi Note 4 przy użyciu Tapatalka
#22
The SMB shares can be easily modified in the config file, feel free to tweak however you would like. The same goes for setting up NFS. The file system is not read only so you have the flexibility of updating these yourself via SSH, as well as adding users. You'd obviously want to then configure the necessary file security for those new users.
Thank you all for your testing and feedback so far! And thank you for your patience, we have in our list to get the eMMC working in a future release. Alpha is alpha, right? Wink
@Raere - thanks for testing! Just for everyone's knowledge, if you can provide the details of USB adapters you tried, it would be great! There's a possibility they can be added later, but at least we will have a list of devices that have been tested Smile
#23
8 and 16 bit console work good. Nintendo 64 and Playstation work good too. But PSP and FBA don't start.
#24
(05-01-2018, 06:43 AM)Des4grea Wrote: 8 and 16 bit console work good. Nintendo 64 and Playstation work good too. But PSP and FBA don't start.
FBA works for me - what are you trying to play? If Neo Geo games, then you need (the correct) neogeo.zip BIOS in the same folder as the games, not in the BIOS folder. In general, put Neo Geo games + BIOS in the neogeo roms folder.
Indeed, PSP doesn't work - already got a report earlier today and error:
Quote:12:35:23    @Substring | lukasz, EGL ERROR: Unable to create EGL display.
#25
Oh my...
Now I have to decide if buy a new SD or an Emmc card to test Recalbox... Big Grin
#26
Yes Neo Geo. OK thank you. What BIOS do I need exactly?
#27
Danielsan, a SD card will do fine for now. In the future you'll be able to boot from HDD or old USB stick  - most people have one or the other in a drawer somewhere collecting dust.
Des4grea, the BIOS needs to contain the following:
[Image: 6LrrMQQ.png]
#28
@Mrfixit2001 The problem is, I have tried to create separate SMB user but didn't work as well as changing password for root user failed.
Shares with forced users or "guest only" worked fine.
Currently I'm back to Ayufan's Debian Jessie but I'm definitely buying mSD for further tests.
I'll try to make it dual boot with priority for eMMC (for everyday's server activities) and Recalbox from mSD "on demand" with minimum media server. Big Grin
...only problem is there is no Xbox One gamepad support.
Next time I flash it I'll test PS4 gamepad over USB and BT but I'd like to use Xbox gamepad as I have it always connected (for GIMX usage) Sad
#29
(05-01-2018, 09:13 AM)S3phi40T Wrote: @Mrfixit2001
Finding a gamepad that works with this board was a pain...
Eventually I found this one which has a reasonable price, good manufacturing, and works out-of-the-box on Linux as well as on Android:
https://gamesir.hk/products/gamesir-g3w
Wink
#30
Wink
On this build the following worked:
BT: 8Bitdo controller
Wired: Xbox 360 and PS3 original controllers, Buffalo retro controller, Fake Xbox 360 controller
These did not work: Fake PS3 controller, no-brand SNES controller.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 13 18,746 06-27-2026, 02:43 PM
  rAudio for Rock64 V2/Pine A64+ shinzuka 11 1,931 06-25-2026, 03:16 PM
Last Post: shinzuka
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,145 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 6,054 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 11,987 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,246 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 3,423 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,401 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  DietPi OS for ROCK64 MichaIng 42 86,885 09-01-2024, 06:43 AM
Last Post: RaymondDay
Smile First Lakka image for Rock64! Luke 47 110,819 09-01-2024, 06:05 AM
