Netrunner 18.03 Idolon for the Pinebook
#21
KDE Plasma is so badly documented online so I have one more question. How to disable asking for sudo password in Konsole or when running some program as root? I tired so many solutions and none of them is working.
Ok, this helped: https://archlinuxhacks.wordpress.com/201...condition/
#22
I hope to try it finally today, I am very curious if it will be at least so fast like current Ubuntu Xenial with KDE Smile
#23
It is working quite decent, so far very happy with everything had no major issues. Wifi is not connecting automatically every time after boot but that is not so major issue. Hope to see more releases in the future.
#24
Time synchronization is not working, I had to do: sudo apt install libnss-systemd, now it is working.
#25
Ok, tried it yesterday and it works fine, I think a little better than Xenial with KDE. I run it from my 32 GB EVO card and it even does not seem so.
Just one thing that I noticed. I was not able to find and install full language support for my language, even though I have it installed in Kubuntu, so a lot of apps are not localized.
I was even able to resize that system partition on SD card on the fly! Smile
#26
Quote:I was even able to resize that system partition on SD card on the fly!
The installer does exactly this.
Languages are now shipped in the kde applications itself instead of a separate language pack. So if you used the installer it should install all those language packages for LibreOffice and Firefox aswell as Thunderbird (so all applications that we ship by default and that don't ship their own languages)
#27
You are right Smile I thought that installer install the system to eMMC.
#28
Does it correctly support suspend mode? I lost about 33 percent of battery with lid closed during the day or night.
#29
Suspend to ram is supported. Not sure if it will engage on lid close if you have power plugged in. See the powersettings for this.
#30
I think it is configured properly. Does it work on your PB?
  DietPi OS for Pinebook MichaIng 5 17,149 07-28-2026, 08:02 PM
  Irradium (based on crux linux) Pinebook A64 (aarch64) mara 4 14,603 05-18-2026, 02:11 PM
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 104,372 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 5,932 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 4,475 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 16,745 04-13-2023, 01:09 PM
  Stock Debian on original Pinebook moonwalkers 1 8,431 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 10,751 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 11,459 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 8,519 01-20-2021, 11:18 AM
