PINE64 Acrylic Open Enclosure
Is the PINE64 Acrylic Open Enclosure case hardware designed in such a way as to make them stackable similar to the below image?
[Image: 51CIdDlsEFL.jpg]
I'm actually going this route since it's a super-simple solution. I just went to an online retailer and ordered several 4" x 6" acrylic sheets of 1/8" thickness (in a pretty blue), and will drill the 4 screw holes myself. There was a $30 minimum order on the sheets, and I was able to get 28 of them for that price, so I'll be able to stack these to my heart's content (or until my wife tells me to knock it off Smile ).
What are you doing for the spacers?
Sent from my SM-T537V using Tapatalk
(03-16-2016, 06:40 PM)jl_678 Wrote: What are you doing for the spacers?
 I'm going to use brass standoffs. l'll use some small ones (something like 8mm) below the board, and taller ones above. In the picture that started the thread, the hex bolts are only used to hold the acrylic slabs together and some kind of plastic piece is used to attach the RasPi to the slab. I decided to have the standoffs do both functions.
I ordered 4" x 6" pieces which will give me ~1/2" of edge on all sides of the Pine64. The mounting holes on the Pine64 are 5mm in from the corner (on the diagonal), so I'll drill 4 holes in my acrylic slabs at 1/2" + 5mm from the corners and attach the Pine64 and attach the acrylic pieces together in one shot.
Only thing I'm still working on is what to do about the "feet" on the underside. I'm looking for some kind of rubber stick-ons or something so I can have a unit that's less likely to slide around since it'll weigh almost nothing.
Okay. Thank you for the clarification. I like your idea!
Sent from my XT1254 using Tapatalk
I should mention, I wanted to go with a bit thicker than a 1/8" (3.17mm) acrylic piece, but the length of the threaded part of the standoffs stymied me on this. The male-side threaded part is only 6mm, so if I got a 1/4" (6.34mm) acrylic piece the standoff hex screw wouldn't reach all the way through.
If you wanted to get slightly more complicated, you could go with any thickness of acrylic you like, and just make sure you get the bottom standoff screws as female on both ends instead of m/f. That way you can run a regular screw (of an appropriate length) into the top and bottom of the unit. So it'd end up looking like this:
Male screw (down through the acrylic piece into the standoff)
______
Top acrylic piece
______
1" m/f standoff screw  (or however long you like based on how much headroom you want/need) with the receive male side pointed up to receive the top screw
______
Pine64
______
8mm f/f standoff screw
______
Male screw (up through the acrylic piece into the standoff)
Adding whatever washers and whatnot you like between any of the junctions.
This process will work only for single units. If you want to stack more than one, you would need to either stick to 1/8" acrylic and use m/f standoffs, or find a m/m screw to join each layer.
Hi !
I also develope one open model enclosure  ...
25mm nylon HEX standoffs  And VESA holes adapter..
Bye
my open housing can be found here http://forum.pine64.org/showthread.php?t...08#pid3808. The cost is only $ 11.50 for a pine. For the second Pine will be added $ 3.70 for the spacers.
(03-23-2016, 10:08 AM)norm24 Wrote: my open housing can be found here http://forum.pine64.org/showthread.php?t...08#pid3808. The cost is only $ 11.50 for a pine. For the second Pine will be added $ 3.70 for the spacers.
Are you selling these anywhere?
Just ordered one through Amazon! Smile Thanks for the great product.
  Are the Pine64 Acrylic Open Enclosures Stackable? abhinava 5 15,910 09-17-2020, 06:41 AM
Last Post: dabou
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 7,243 11-12-2019, 04:52 AM
Last Post: xalius
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 32,683 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 51,502 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
  A case with active cooling for 1Gb pine64 ishwest 5 16,554 06-28-2017, 04:05 AM
Last Post: ishwest
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 10,526 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 12,910 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 9,919 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 21,170 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 39,142 01-06-2017, 03:15 AM
Last Post: Learnincurve
