RPi.GPIO python module for Pine A64/A64+
#91
(04-10-2018, 03:17 AM)xalius Wrote: Are you using spidev?
I'm not sure, but I don't think so. I put my code on github here so you can see what I'm doing.
I initially took the code from Adafruit, but since this library uses a different implementation for SPI (and I2C) I modified it to work on the pine64.
Nokia5110.py is my modified library.
nokia_test2.py draws some shapes and text on the display.
nokia_clock2.py draws a very simple analog clock.
Can you pastebin the debug output you see on your console?
(04-12-2018, 03:54 AM)xalius Wrote: Can you pastebin the debug output you see on your console?
sure here's a snippet of it:
tx[0]=00
tx[1]=00
tx[2]=00
tx[3]=00
tx[4]=00
tx[5]=00
tx[6]=00
tx[7]=00
tx[8]=00
tx[9]=00
tx[10]=00
It looks like whatever is being sent over SPI is also being dumped to the screen. I'd like to be able to turn this off, as it makes it difficult to find anything else that I try printing.
I endeavored to introduce it. Amid the establishment, it gived to me a blunder:
"Python.h can't discovered record or catalog"
I am certain to have Python introduced, in such a case that I express "python" in terminal, it returns me the adaptation
Python Training
Has there been any change in this of late? I'm trying to resurrect some old python2 code on my pine64s (and port it to python3) but installing via library by cloning the repo and doing a `sudo python setup.py install` on a fresh build of Manjaro ARM is getting me the dreaded errror:
Traceback (most recent call last):
  File "./pine64-fan-control.py", line 9, in <module>
    from RPi import GPIO as GPIO
  File "/usr/lib/python3.8/site-packages/RPi/GPIO/__init__.py", line 23, in <module>
    from RPi._GPIO import *
RuntimeError: This module can only be run on a Raspberry Pi!
Idealy I'd install it in a venv, but I'm not that far yet, and I've not installed the 'official' RPI version, so basically no idea what's going on now!
I am also interested if anyone ever got event detection (interrupts) to work and if so what modificaitons were made to the dts to enable this?
MarkHaysHarris777 Wrote:the module name should be RPi.GPIO,  not RPi._GPIO
I am looking for steps to download and install RPi.GPIO on my Pine64 A64. For some reason my original SD card and steps from 2016 are missing and my SD card is corrupt. This is possibly why it was moth-balled. BUt I am revisiting and have Armbian image installed and have HDMI and LCD, WIFI and BT working. Now I'd like to get this SBC to control a Robot. I could not get RPi.GPIO or Wiring to install
Hi all,
i've the following error when I try to install RPi.GPIO-PineA64 via command sudo python3 setup.py install:
source/py_gpio.c: In function ‘py_setup_channel’:
/usr/include/python3.9/object.h:633:41: error: expected ‘(’ before ‘PyType_HasFeature’
633 | #define PyType_FastSubclass(type, flag) PyType_HasFeature(type, flag)
/usr/include/python3.9/listobject.h:25:5: note: in expansion of macro ‘PyType_FastSubclass’
25 | PyType_FastSubclass(Py_TYPE(op), Py_TPFLAGS_LIST_SUBCLASS)
source/py_gpio.c:247:14: note: in expansion of macro ‘PyList_Check’
247 | } else if PyList_Check(chanlist) {
source/py_gpio.c:247:37: error: expected ‘;’ before ‘{’ token
source/py_gpio.c: In function ‘chan_from_gpio’:
source/py_gpio.c:580:39: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
580 | if (*(pinToGpioPineA64+chan) == gpio)
source/py_gpio.c:592:32: warning: comparison of integer expressions of different signedness: ‘int’ and ‘unsigned int’ [-Wsign-compare]
592 | if (*(*pin_to_gpio+chan) == gpio)
source/py_gpio.c: In function ‘PyInit__GPIO’:
source/py_gpio.c:1065:4: warning: ‘PyEval_ThreadsInitialized’ is deprecated [-Wdeprecated-declarations]
1065 | if (!PyEval_ThreadsInitialized())
In file included from /usr/include/python3.9/Python.h:145,
from source/py_gpio.c:23:
/usr/include/python3.9/ceval.h:129:36: note: declared here
129 | Py_DEPRECATED(3.9) PyAPI_FUNC(int) PyEval_ThreadsInitialized(void);
source/py_gpio.c:1066:7: warning: ‘PyEval_InitThreads’ is deprecated [-Wdeprecated-declarations]
1066 | PyEval_InitThreads();
/usr/include/python3.9/ceval.h:130:37: note: declared here
130 | Py_DEPRECATED(3.9) PyAPI_FUNC(void) PyEval_InitThreads(void);
error: command '/usr/bin/aarch64-linux-gnu-gcc' failed with exit code 1
Can anyone helps me to find out the solution?
MT
After hearing a few stories of friends catching cancer early, I started thinking about getting screened myself. I came across this test that offers early cancer detection. It’s great to know that there are tests available that don’t wait for symptoms to show up. Here’s more info: https://ways2well.com/product/cancer-detection-test. It might just be the peace of mind I need moving forward with my health checks.
Finding hardware-software stability on open-source single-board setups can be challenging, which is why I like keeping an eye on community threads about Linux optimization. When tweaking custom builds on mobile hardware, having a responsive UI for daily tasks is everything. Out of curiosity, I ended up testing how smooth standard web tasks and financial dashboards run on these portable setups compared to an official mobile OS environment like iOS. Running a dedicated crypto wallet app on a standard iPhone shows just how seamless transaction monitoring and price tracking should feel when optimization is done right. Clean interface responsiveness is definitely the benchmark we should strive for across all portable devices.
  fm transmitter with gpio weasel18 2 8,183 09-10-2019, 04:28 AM
Last Post: desai_amogh
  How to use dts or other setup to declare gpio pin Interrupt (e.g. a button)? dkebler 1 6,013 06-12-2019, 10:37 AM
Last Post: dkebler
Lightbulb Sample GPIO codes highlighting RPi.GPIO-PineA64 and the PI bus MarkHaysHarris777 6 17,874 06-07-2019, 12:37 AM
Star GPIO, SPI and I2C C++ Lib databit 7 17,438 02-04-2019, 05:45 AM
Last Post: Jeff R
Information Howto: Controlling Pine64 GPIO via the filesystem (sysfs) on linux pfeerick 4 18,184 01-24-2019, 03:36 AM
Last Post: Fifth
  GPIO and SPI SamR1 20 48,699 03-15-2018, 10:32 AM
Last Post: jomoengineer
Question GPIO shockr 7 22,565 03-11-2018, 01:52 AM
  Read GPIO problem shworker 14 34,171 08-17-2017, 01:21 PM
Last Post: martinayotte
  Cross-wired Uart Ports between two Pine Boards via Cat5 Cable MarkHaysHarris777 10 25,480 11-20-2016, 04:17 AM
Last Post: pfeerick
  GPIO fiq capability joseph 3 9,869 11-10-2016, 06:07 PM
Last Post: joseph
