A good desktop experience on Rock64
#21
Path to script: /usr/local/sbin
(03-17-2018, 01:25 PM)Luke Wrote: Path to script: /usr/local/sbin
so the command should be ./usr/local/sbin/install_desktop.sh lxde ?
perhaps i am missing something obvious, but
sudo ./install install_desktop.sh lxde
fails, even if you are in the correct directory, right?
yeah, you are missing something. the command is
sudo ./install_desktop.sh lxde
from the proper directory, /usr/local/sbin
not sure were your second install came from. also check for proper permissions on that file.
(03-17-2018, 07:58 PM)dkryder Wrote: yeah, you are missing something. the command is
The second install came from the first post...
For me the command ran but failed with dependencies errors (ffmepg and mpv iirc)
And only in case there where some pathing error on the script i did a:
cd /usr/loca/sbin
oh that, an obvious attempt to mess with the noobs. +1 for you.
my perception of the obvious borders on the phenomenal
thank you for helping me to not feel insane fora few moments
Corrected the first post ... must have gotten distracted while typing out the instructions. My apologies.
I have Linux from ayufan version 0.6.25 (updated from 0.6.23).
I tried to install lxde, mate and gnome, all the installation goes without errors but after restarting see a black screen. (when removing installed packages, I noticed that the system reported that there were no packages already installed, although there were no errors during installation)
On the newly downloaded 0.6.25 and written to a clean memory card, the graphical environment is not installed at all with the errors of the ffmpeg and MPV dependencies
p. s. sorry for my English Smile
Starting with 0.6.34 Bionic with LXDE is available for download; no need to install the desktop and related packages manually.
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 14 20,991 09-27-2026, 11:55 AM
  rAudio for Rock64 V2/Pine A64+ shinzuka 14 4,606 07-31-2026, 03:20 AM
Last Post: shinzuka
  DietPi OS for ROCK64 MichaIng 43 95,465 07-22-2026, 01:47 PM
Last Post: MichaIng
  Rock64 v3 Tx/RX and GPIO connections for 3dprinter MinimumJargon 2 1,956 01-28-2026, 04:04 AM
Last Post: alicesphere
  Rock64 - not booting after Armbian update helpmerock 7 7,323 01-24-2026, 04:44 PM
Last Post: ff255
  Xen hypervisor on Rock64 tumbleweed 6 13,303 11-03-2025, 09:25 AM
Last Post: darkfader
  can rock64 4gb ram run entirely on free software? heocb 1 3,883 01-07-2025, 05:47 AM
  Upgrading ancient Rock64 timxjr1300 1 4,054 11-26-2024, 09:47 AM
Last Post: dmitrymyadzelets
  arch rock64 does not boot nemnob 1 4,949 09-20-2024, 11:18 AM
Last Post: AwU2HBg
Smile First Lakka image for Rock64! Luke 47 116,919 09-01-2024, 06:05 AM
Last Post: RaymondDay
