Installing Android on SD Card
Hi
I am trying to install Andorid on my Rock64 but no matter what image i pick, i get the same error. I have downloaded the installer and created my SD Card using that.
This is the error i am getting when i turn on the Rock64. It shows the boot logo and then i get this
https://imgur.com/UStltls
Anyone know what i am doing wrong?
You can try to use another sd card.
Maybe it is corrupted?
I have installed LibreELEC and got that working on the Rock64 and have also tested the card on my Raspberry Pi, so i don't think it's the card. It's a brand new card bought with the Rock64 from the site.
Please try to flash (using etcher) this image and let us know if it boots
(03-14-2018, 01:38 PM)Luke Wrote: Please try to flash (using etcher) this image and let us know if it boots
I tried that now and still get same error :/
I have many problems with sd cards too.
I will try to be brief Wink.
So when i flash Android to "MediaRange micro sd hc 16GB class10", at first boot it works very good and the system is very fast, but when i reboot my rock64 it's going immediatly to recovery... I must wipe the system completely then it boots like the first time.
With "SanDisk 16GB hc I class10" the system  (android) is very slow ,but there is no problem at reboot.
With "Samsung 32GB evo+" it,s a little less slow...
So it really depends of sd card.
(03-14-2018, 01:12 PM)Phingum Wrote: I have installed LibreELEC and got that working on the Rock64 and have also tested the card on my Raspberry Pi, so i don't think it's the card. It's a brand new card bought with the Rock64 from the site.
I've just received two brand new Rock64 boards. I've tried Android from your link... damn, I really expected something better from this device Undecided  Getting lot's of "isn't responding" messages on the screen. There is probably something wrong with this Android, it shouldn't be THAT slow...
Yeah, I'm in the same boat.  Saw some press on the board and thought it'd be great, but I was only able to get it to boot android once and when I hooked it up to the TV, the audio was crap.  Now I can't even get that.
Would like an Android TV device that doesn't suck - I've tried the MK808 (Wifi never worked), MiBox (netflix stopped working after a week), and this with no luck.
(06-24-2018, 07:48 PM)dshookowsky Wrote: Yeah, I'm in the same boat.  Saw some press on the board and thought it'd be great, but I was only able to get it to boot android once and when I hooked it up to the TV, the audio was crap.  Now I can't even get that.
I haven't used the android build in a while, but with any SBC the most common pitfalls are dodgy power supply or crap microSD card. If you're using the stock power supply that shouldn't be an issue. And I would strongly recommend you try using a Samsung EVO card if you aren't already. Your existing card might be good for phones, cameras, etc, and even claim higher performance specs than the Samsung EVO series, but the card brand/type DOES matter, and is critical with Android as it is heavy on SD card usage. I didn't have any issues with my rock64s when I was trying some of the Android builds before. There has also just been a release of a Android 8.1 for the rock64 that might be worth trying
  Android Images (ROCK64) pineadmin 77 247,061 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,534 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,810 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,984 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,953 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,657 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,813 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,494 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,738 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 9,102 09-18-2020, 07:58 PM
Last Post: BowerR64
