Debian image takes all Free Space
I have Debian Stretch Mate Community Build Image [microSD Boot] [0.5.15-136-20171222] flashed to a 256GB SD card and when trying to run sudo apt-et update, i get errors that there is no space left on the device: "Error writing to output file - write (28: No space left on device) Error writing to file - write (28: No space left on device) "
Running df I see this output:
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
Last login: Wed Feb 28 13:58:01 2018 from 192.168.111.122
rock64@rock64:~$ df
Filesystem     1K-blocks      Used Available Use% Mounted on
udev             2007908         0   2007908   0% /dev
tmpfs             401960     10472    391488   3% /run
/dev/mmcblk1p7 261901060 261215864         0 100% /
tmpfs            2009784         0   2009784   0% /dev/shm
tmpfs               5120         4      5116   1% /run/lock
tmpfs            2009784         0   2009784   0% /sys/fs/cgroup
/dev/mmcblk1p6    102182     41642     60540  41% /boot/efi
tmpfs             401956         4    401952   1% /run/user/109
tmpfs             401956         0    401956   0% /run/user/1000
I get that /dev/mmcblk1p7 261901060 261215864         0 100% /   shows 100% full but I am not sure if this is to be expected and I wont get to use a card like this for storage as well as the OS. I am a debian noob so if I flashed it wrong with Etcher or if I just need to use a smaller card and use the emmc port or USB3.0 for data storage tats fine. Just wanted to see what was to be expected.
What brand/type of card is your 256GB? Also can you post the output of
sudo fdisk -l /dev/mmcblk1
in my opinion you would certainly be having less risk if you would usie 32GB or 16GB. by less risk i mean sd cards are relatively easy to damage just by normal day to day usage and those 256GB cards are expensive and at least for me would be taking too much risk with day to day single board computer usage. if you actually need that much room look into booting from flash to a usb hard disk.
  can rock64 4gb ram run entirely on free software? heocb 1 3,632 01-07-2025, 05:47 AM
  problem with debian emmc boot G4zCDzWb 10 30,006 11-01-2024, 04:32 PM
Last Post: bits
  Debian installation via sd card oaFJSADBKV 0 2,484 10-12-2024, 10:24 AM
Last Post: oaFJSADBKV
Smile First Lakka image for Rock64! Luke 47 114,177 09-01-2024, 06:05 AM
Last Post: RaymondDay
  How to update/compile Debian 12.5? Wizardknight 3 4,964 03-29-2024, 05:01 AM
Last Post: gedas07
  Rock64 Debian 11 (Bullseye) install problem jbize 15 23,426 10-12-2023, 05:14 PM
Last Post: tpaul
  rock64-debian-mrfixit-190531.img.xz : missing /usr/lib/dri/rockchip_dri.so popi 5 9,875 08-12-2021, 04:55 AM
Last Post: igorp
  Debian build from mrfixit2001 Luke 18 43,019 05-17-2021, 02:35 AM
Last Post: Wizzard
  NextCloudPi image for Rock64, NC version 13.0.2. nachoparker 11 37,085 03-15-2021, 02:59 PM
Last Post: kiriakos
  Debian kernel stuck at 4.4.167 Enig123 5 10,421 12-29-2020, 12:57 PM
Last Post: kwinz
